Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Working on Mavie 2 today - another employee wreck. 🙄
This isn't the SAME Mav in your Youtube wreck-repair videos.???.. Say it ain't soo.... :eek:
Jerry
Maverickman74
Shane
Maui HI
Huh, you learn something everyday. I would have assumed that since these are unibody that all the panels would be welded on.
My mind immediately went to some fiberglass box flare fenders. Hmmm...
Or what about utility bed sides with storage boxes?
Something like this:
The sweet thing is that you will have the full flex bed instead of the often too narrow bed on the midsize utility trucks. Also it would be easier to ship and produce as a kit.
Decayed
yes
a car
Maybe a widebody kit and duals on the back?
Asking for a friend. HRG
Top it off with "Super Duty" badges. Heads would explode, literally.
Redneck Garage
Redneck Garage
Franklin TN
www.theredneckgarage.com
This isn't the SAME Mav in your Youtube wreck-repair videos.???.. Say it ain't soo.... 🤪
Jerry
Yes....... I'm thrilled. There has been some career counseling as in "last chance" even if you do pay for repairs.
JP4AZ
Phoenix
David, You have the patience of a "Saint" with your employee/family member.
Redneck Garage
Redneck Garage
Franklin TN
Totally agree, but a body shop would probably spend more money in labor trying to not break plastic clips and salvaging them....body work is so labor extensive/expensive.
You can see the necked structure is so fragile looking that a Maverick, OR ANY NEW MODERN DAY VEHICLE without a frame is so easy to be totaled. Everything crumples for safety and is not designed for easy repair at a body shop. Every things attached with plastic clips or glue. So many rear-ended Mavericks, reported on this site, are TOTALLED. I will predict auto insurance rates of the future will be a steady rise in costs.
I hear ya however not being able to assemble a truck because of waiting for 6 specialty clips and trying to order the right ones when it takes less than 2 minutes to pull them - yeah they pull the old ones. Sadly they also charged for the new ones probably at $22.00 each - the same fasteners that never were ordered as well as anything else that could be added. The top rail plastic cap on the bed is easily removed but every estimate Ive seen shows replacement - you think that replacement happened ? How much would you bet the tail light that wasnt damaged on my truck would be in there on an estimate ? Yeah some are totaled however Ive seen MANY that should have been repaired except for the padded estimate.
Redneck Garage
Redneck Garage
Franklin TN
Sadly that is true. It is running out tho lol
Bruce W
Bruce
Brookings, SD
2022 Ford Maverick Hybrid Latiat
Working on Mavie 2 today - another employee wreck. Video coming soon. I can verify that it is 100% bolt on and no spot welds. Hey I'm going glass half full lol. Thought everyone would enjoy seeing the skeleton on the rear of the Maverick. My warped mind also thought it wouldn't be that hard to produce some bolt on panels that turned it into a step side 🙄
What does the backside of the fender look like?
Redneck Garage
Redneck Garage
Franklin TN
It looked just like the exposed metal under the quarter panel. Both are coated in I assume zinc based / anti corrosion primer. Evidently it works pretty well as there isnt any evidence of rust anywhere underneath. Ill add a shot in the video for you of the back of the fender :)
Redneck Garage
Redneck Garage
Franklin TN
As a side note - From Bruce W 's question, I wondered about the coating. There was a video about the Hermosillo plant and assembly - it shows some of the painting process however the system made by Durr actually coats the entire vehicle with a phosphate primer coating by dunking the whole thing in a huge vat of paint thus covering every surface. Almost identical to their operation in Thailand -
Ford Maverick DIY Quarter Panel Replacement - So Fun Screenshot 2023-09-10 100002
After that drains, goes thru an oven it is ready for robotic painting.
Ford Maverick DIY Quarter Panel Replacement - So Fun Screenshot 2023-09-10 095504
Ford Maverick DIY Quarter Panel Replacement - So Fun Screenshot 2023-09-10 113250
Yes, the robot will actually open the doors and hood to paint the interior as it moves thru the booth. The tailgate is painted separately on a jig rear of the truck. .
The robotic painting is electrostatic and the paint actually is "attracted" to the truck using a ground thus it flows into areas like the door jams.
Ford Maverick DIY Quarter Panel Replacement - So Fun Screenshot 2023-09-10 100640
From my photo you can tell that the white area are really areas of overspray on the phosphate undercoating done by the robots.
Ford Maverick DIY Quarter Panel Replacement - So Fun rear
So the answer to - what does the back of the fender look like - is it looks just like the rest of the unpainted areas as the complete truck is dipped in the primer tank covering every surface before painting :)
Ford Maverick DIY Quarter Panel Replacement - So Fun Screenshot 2023-09-10 111909
Ford Maverick DIY Quarter Panel Replacement - So Fun Screenshot 2023-09-10 100014
RLmesc
Randy
Dubuque, Ia
18 Kia Sportage, 05 Porsche Boxster S, 85 Kawasaki
I am not sure that the unibody inner structure can withstand the stress of the storage compartments body PLUS the weight of tools and supply by simply bolting this on like the rear quarter panels do.
