DIY bike rack
mav_nav
MI
Something like this attached to a 2x4? My bike doesn't have a quick release, so I am also looking for a DIY solution which doesn't involve taking the wheel off
Ford Maverick DIY bike rack DIY truck bed bike rack
Phranc68
Phranc68
Frank
Olympia
Maverick, Ram 3500, Honda Odyssey
I just turned the bike sideways
Why wouldn't you just lay the bike down in the bed? Catty-corner, could probably close the TG.
I took your advice, the bike stands perfectly on the diagonal. Anchor a strap (wrapped once on the frame) to the tie down of your choice and it's secure. Tailgate closes.
Chris McD
Norwalk, CA
2022 Ford Maverick XLT
Jakb
Jak
Minneapolis, mn
23 XLT Hybrid
I will be interested in what you come up with as well. Appreciate if you post it. Thx!
It's not the cheapest but i bought some custom cut 80/20 to go across the bed in the flexbed slots
Ford Maverick DIY bike rack 20211224_145001
The Thule has bolts to fit, they just need a tiny bit shaved off
1534-Lite
Ford Maverick DIY bike rack 20211224_145028
1503 1.5x
Ford Maverick DIY bike rack 20211224_145018
The hope is once I get the truck i can grind away the edges and put some rubber ends on there. They will fit right into the slots and be easily removable and collapsible.
Overall it's not cheap but it should be a quick in and out.
Phranc68
Phranc68
Frank
Olympia
1534-Lite
1503 1.5x
I love it. Well done. Will your bike fit with the tailgate closed?
My current set up rides just higher than the tailgate for both my skis and bike
Ford Maverick DIY bike rack PXL_20211205_164718908
Jakb
Jak
Minneapolis, mn
23 XLT Hybrid
I still don't have a build date so i dunno officially. I'm pretty confident it won't close as I ride a larger bicycle, but my main goal was to have it sit lower in the bed and be compatable with a trifold.
I'll let you know how it fits in.....March?
Phranc68
Phranc68
Frank
Olympia
I still don't have a build date so i dunno officially. I'm pretty confident it won't close as I ride a larger bicycle, but my main goal was to have it sit lower in the bed and be comparable with a trifold.
Good luck and I hope it's sooner!
Phranc68
Phranc68
Frank
Olympia
Well done!
which07
CW
NY
Infiniti QX60
Do yo have any issues with the bikes rubbing on each other?
I use adjustable rachet tie-down straps to the D-rings, no problems. I have switched to a tailhitch bike carrier recently to carry other items in the bed.
710-oil-614
Cal
2025 Hybrid AWD Lariat
If you did that with a carbon frame, you'd have a VERY good chance of cracking the downtube, especially on a bumpy road surface.
(USAC Licensed Mechanic)
How is that any different than my hitch mount rack that applies pressure to the top tube?
