Diode Dynamics fog lights
Lgoodso
Lgoodso
Larry
Drummonds,Tn
2015ford f250 ,2023Ford maverick 53&57chevy truck
Which OBDII do I need so I can connect my laptop?
I used OBD Link Ex, it’s designed for Forscan and Ford vehicles.
Jose A
Jose
2024 Maverick XLT Hybrid
I ordered and received the OBDII connector the other day. How difficult is it to get to the BCM? Do you have video or photo of you getting to it? I'm sure I can YouTube it but just asking since I'll follow your instructions on installing the DD fog lights.
Tbone289
For those of you using the Ford switch... How are you wiring the amber backlight?
I was thinking of wiring the backlight circuit to the parking lights either up front or at the BCM, but wanted your input first. Thanks.
MaverickDragon
Grand Canyon, AZ
@Lgoodso
Nice install.
I wish I had your garage!
Lgoodso
Lgoodso
Larry
Drummonds,Tn
It’s on the passenger side toe board real easy to get to.
CNJFF
NJ
Under the passenger dash pull out the floor mat and there is a rectangular plastic cover against the firewall. Grab both sides near the top and give it a good yank. Use the crease lines in the carpet to align it back when done.
Jose A
Jose
Ok. Thanks. I’ll take a look tomorrow morning to see what you’re referring to
svallee87
DFW
2024 Ford Maverick XLT AWD
Merry Christmas everyone. I’m looking for the rubber plug/knockout that the white wire for the kit is being ran through. I’ve already pinned the bcm connector and programmed with forscan, ran a jumper from green to white outside the vehicle to verify. For the life of me I’m not able to see where I can run it out into the engine compartment. Thank you in advance
Carlitos_92
Straight from the DD instructions... Brake pedal and steering linkage visible in photo. Should be something similar on the BCM side if that is your preference.
Ford Maverick Diode Dynamics fog lights 1766689144358-c9
Jose A
Jose
I assisted Larry with the fog light wiring change today for the Diode Dynamic fog light kit. It was initially installed per the instructions received from Diode Dynamic. The toggle switch was wired and placed under the dash. The F-150 headlight switch, (part number in the first post), was installed, but did not allow us to enable the fog light indicator on the dash or be able to use the push button on the head light switch to turn on the fog lights because the power was not being provided by BCM. He was able to find the correct pins and location of BCM connector through researching other posts that are currently active. He ordered two wires with the correct connector pin, (part number in first post), to add to the BCM connector to power the fog lights. Today he wanted to find the way to connect the BCM to the existing Diode Dynamic wiring harness. The wiring changes were minimal. The toggle switch was removed along with the two existing wires connected to it that ran to the switch input line and the passenger side headlight wire harness. The remaining Diode Dynamics wiring harness was left in place. This was convenient because the front grill of the truck did not need to be removed to complete this wiring change. The two pins, pin 6 and 7, at the BCM are power wires for the fog lights. One is for the left fog light and the other is for the right fog light. We only had to add one wire at the BCM connector because we did not remove the Diode Dynamics wiring harness. This allowed the one power wire to apply power to both fog lights through the Diode Dynamics wiring harness. The new wire from the BCM was connected to the switch input wire that had been connected to one side of the toggle switch that was removed. That completed the wiring changes for his fog light install today.
We moved on to the Forscan changes that allow for the fog light dash indicator to work. Two modules are involed in the required changes for his 2023 Ford Maverick XLT. I will list them separately.
IPC Module
Front Fog Lamps (default is disabled) - Change to enabled
BCM Module
Fog Lamp Usage - Fog Only
Front fog lamps - (default is disabled) - Enabled
Fog Lamp Switch (default is not available) - Available
Fog Lamp Switch Type (default is hardwire) - LIN
*Left Front Fog Lamp Usage (default is not used) - Fog only (providing power from the BCM)
*Right Front Fog Lamp Usage - Not Used (We only needed one power input since the Diode Dynamic wiring harness was ran to both fog lamps.)
*We initially used both the left and right option becasue we could not remember which pin we chose to use to send power to the fog lights from the BCM. After we tested that everything worked, we disabled the pin that we did not install a wire into during the wiring change.
The fog light indicator is now working and he can use the push button on the F-150 headlight switch to turn them on or off. The fog lights automatically turn off when the high beams are turned on. The amber back lighting is working correctly. The Diode Dynamic fog lights, custom wiring and F-150 headlight switch give his truck a factory feel.
Jose A
Jose
So I just installed the fog lights but did not install the toggle switch or the harness. I bought the F150 fog light switch but I'm confused on where to install the green terminal wire. I know the wire goes to BCM #6 but where do I put the other end? I would assume it goes to the fog light switch. Am I correct or where do I put it?
Carlitos_92
The way most people have been wiring it, that BCM wire is the actual 12VDC+ power for the light(s). The LED fog lights are a small enough load that the BCM will power them. After programming with Forscan, all the F-150 switch does is digitally tell the BCM to send power out that new wire.
Jose A
Jose
Can you show me where to connect the end of the green wire coming out of the BCM? I had to do the install per DD instructions for the lights to come on. I made the changes in ForScan but it didn't work. There doesn't seem to be any power coming from pin #6 when checked with voltmeter.
CNJFF
NJ
Make sure you change all appropriate settings in FORScan (Post #2). If you have trouble finding a setting, enter the module and filter for "fog".
The wire off Pin 6 (or 7) becomes your power to the lights (red wire).
