Did they change the sound system with the 2025s?
colinl
Colin
ICT
someone needs to pull door cover look at speaker. lol
I'm highly confident someone is already upgrading their MY25 sound, we just need them to take pics and post about it. (y)
squirlz
Madison, WI
2025 Maverick XLT Hybrid AWD
I plan on taking some measurements of the B&O this weekend to compare against the base audio system.
Base Audio Measurements
I can pull a door panel and take some pictures of the speaker, I need to do some more research anyway. I plan on a full audio upgrade once the weather warms up.
squirlz
Madison, WI
I did get measurements of the B&O with some help from a friend. I will get a post put together with those results soon.
They did not change the door speaker, I did not pull the front tweeter or the rear.
Ford Maverick Did they change the sound system with the 2025s? door speaker 1
Ford Maverick Did they change the sound system with the 2025s? door speaker 2
Toddman45
Todd
St. Louis, MO
I'm sure the speakers are all the same. I highly doubt on a refresh that the speaker quality or components have changed.
Deleted member 5597
Guest
So, I’m amazed by how many people want to listen to concert level music while driving your Maverick safely with all senses available. Hearing is an important part of driving!
With that in mind, I’m perfectly happy with the sound of my B&O Sound System in my ‘22 Lariat! I don’t need to boom shakkalakka in my seat while driving.
Aaron F
Aaron
Sterling Heights, MI
2023 Maverick Lariat Lux w/ 4k and BAP / 2025 Maverick AWD Hybrid Lariat w/ 4k
Sometimes it isn't about concert level. For some people, it is more important about the sound being clean, clear, and accurate too the original track, with decent imaging where the sound seems like it's coming from the center of a stage in front of you. It isn't much different than people wanting a full surround sound experience like the theater in their home.
Toddman45
Todd
St. Louis, MO
It's more about turning on a good song and actually hearing all the nuances from a scratchy guitar pick, to raspy vocals. Or the way the highs of a guitar solo sound or the low thump from a bass drum when played from a 10" sub. Versus mediocrity at best from what the manufacturer puts in there and charged extra for.
This guy gets it.
squirlz
Madison, WI
A quick teaser.
Base vs B&O flat EQ with 60/40 front bias fade volume of both at 12.
Orange is B&O, Green is base.
The B&O has a more flat response, and even a slight rise around 850 Hz and obviously the sub 100 Hz gain from the sub woofer.
Ford Maverick Did they change the sound system with the 2025s? base_vs_bo
FreedomPenguin
Dayton
A quick teaser.
What does this mean in laymen terms? Much difference?
squirlz
Madison, WI
Listening tells me that the center channel speaker does really well at bringing the imaging higher on the dash, still not eye level, but noticeably higher than the base audio. Looking at near field measurements, measurements directly in front of the speaker, it shows the door speakers have an added low pass crossover which will also help bring the image higher, by reducing the vocal range that the door speakers play.
Overall the sound is much more full, brighter mid range from the center channel, and a fuller bottom end from the subwoofer. It is a noticeable upgrade. If you are an audiophile I am not sure it is enough, but if you only planned on replacing speakers and adding a subwoofer I would say it would probably suit your needs. The base is not overpowering, very well balanced, if you want window shaking bass this will not be enough.
FreedomPenguin
Dayton
would this compliment the system in lieu of the stock sub?
https://www.crutchfield.com/S-mWSnZcdHZkf/p_20651HS10/Kicker-51HS10.html
squirlz
Madison, WI
I would expect that to have more output than the factory sub. I believe people who have these are happy with them but they would know more than me.
FreedomPenguin
Dayton
If you had to toss a price on the sound difference in your terms of money value.
100-200-400-600 better?
squirlz
Madison, WI
That is a tough question. Someone can easily add a subwoofer as you suggested, this solves a lot of the issues of the base audio setup. I would think this would solve the issue for most people, so in this case $400, but even at that point they are still not equal.
But if you are more concerned about imaging, that is not something you can change by replacing speakers or just simply add another piece of equipment.. It would require heavy modification such as adding a 3 way front end which would entail fabricating custom A pillars or modifying the dash to fit bigger speakers. The result will be far better than the B&O system but at a cost of thousands of dollars even if you can do the fabrication yourself. If you are an audiophile no factory audio setup will ever be good enough.
If you enjoy music, want more realistic sound production, want the reliability of factory equipment, and want other features offered by the Lariot or higher trims, the B&O setup is a great addition. The center speaker is what separates it from the base setup.
