There are quite a few threads in MTC about flat towing that I've been involved with, and I have gotten quite a few PMs about the install from members here as well as a Facebook group. So I made a file.
I had quickly put together a file in late January, but when I reviewed it, I realized that I had left a bit out. So I went back and tried to fill in the blanks today and remove typos.
Even if you do not want to attempt the relatively easy install, there may be some pointers you can see and share with your installer. It is a fairly easy install for the baseplate; wiring is always a pain.
My experience is that if you are in a hurry, buying directly from Demco was the fastest; and usually Tweetys is the least expensive.
Hope this helps someone here.
