- First Name
- Larry
- Sep 7, 2021
- Massachusetts
- 92 Toyota Pickup. 22 IS hybrid Maverick. ‘25 Hybrid RAV4
- Engine
- 2.5L Hybrid
See post #50.Has anyone else noticed the message in the Ford app has changed? - Instead of 'deep sleep' the random message may now state that the vehicle has gone into battery conservation mode, nothing is wrong, to turn remote features back on drive your vehicle, blah, blah, blah, rather than state Deep Sleep 90% of the time.
For what it's worth my random messages only began in late Aug or early Sept, after spending several hours around the vehicle, which may keep the electronics awake. - Washing & detailing both the Mav and my wife's Crosstrek in the driveway.
The 12v feeds shows 14.5v or higher when the ignition is on, so I'm inclined to believe its charging the battery, or trying to charge the battery. I strongly suspect that the issues are the Chinese made batteries being used. (Most of the OEM batteries appear to carry a made in China label). I really need to run a line out, connect up the automatic desulfator/charger and see what it indicates, along with the battery tester.
For maintaining or just lightly charging, are you disconnecting the battery, or while still connected in the vehicle? - And if the former, how many of the settings are lost. (My Subaru would loose radio pre-sets, PCM learning, TCM learning, and required a Throttle Position Re-Learn if the battery was disconnected).
Thanks
