Clunk, Clunk Every Time I Start Moving/Turning
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
Both are very easy to access and just use a cheap hand pump to refill.
I guess my question is if the fluid is just low or if the unit is damaged. I can address the fluid. Replacing the part is beyond me.
Maverick2022XL
name
hinterlands
It could also be a software issue if it is related to the RDU/AWD system. With forscan software you can try to reprogram or reset adaptations for the PCM module. The other way to do so without forscan is to disconnect the battery for a couple of minutes. This will force a reboot of the PCM which also resets all learned adaptations. You may need to drive the truck a few times before it fully relearns the settings though.
Maverick2022XL
name
hinterlands
If you do get under there to change the fluid also check the wire harness to the RDU unit for any corrosion.
Sovande
Alexandria, VA
2024 Maverick XLT
There is a TSB for the issue. It's known to Ford. It has nothing to do with the software and everything to do with the clutch packs.
Maverick2022XL
name
hinterlands
If it is, then it is but resetting the PCM first is the least invasive check without knowing for sure.
Finnster
N. E. Wisconsin
Chevy, Kia, and a 2025 Maverick Hybrid 4K Tow
Yes, the amount pictured was factory fill levels. Both were low. I changed the trans fluid too. If I were to do that again, I would just drain about 1/2 quart and refill. Fluid looked great and my only real concern for the trans would be the factory fill level.
Can you tell us how much accumulation was on the eCVT drain plug?
Thanks!
Catrikerider
2025 Maverick XLT hybrid AWD 4kt
Probably the RDU. Mine does the same thing. Spoke to the service guy at the dealership and he said the ship date for the backordered units is the end of next month. So likely October before they are available. Nice huh? Mine only lasted 17,500 miles.
Mine is clunking on acceleration already, 8k miles. Quality item, right there.
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
Yeah overall it’s a real bummer. I’ve had this truck since 2022 and for the most part it has done everything I’ve asked it to do. Between the stereo unit constantly floundering with CarPlay, Bluetooth and now even just the radio station, this RDU clunk and my driver door hinge sounds like it’s about to pull out of my door every time I open it, I’m starting to question tough is ford tough. It’s a shame as my 1990 Ranger was slow as can be with its 4 cylinder 5 speed but it got great mileage and delivered on all truck things without a hitch even after I got hit at 45 mph. Literally drove it home.
Catrikerider
Yep.
I realize cars all have their issues, and no manufacturer is perfect.
However, from my personal perspective, the last domestic brand vehicle I bought new was a 1997 Saturn. The kind of stuff my Maverick has going on is largely what made me move to Asian brands. I had a long string of problem free Toyotas since, to include a current 2018 Prius with 130k on it that has never had one failure outside of a blown out tire and a 12v battery that went south at 100k. My wife’s Corolla Cross hybrid has never been to the dealership outside of an oil change.
Therefore, the little things with my Mav, despite them being relatively minor, are kind of a turn off, and just reinforce why I left domestics long ago. I realize Toyota has their problems these days, but in my experience, I’ve not had to deal with little annoyances like my Mav has for a long time.
It was a big roll of the dice in my mind to buy a Ford, to be honest. The package was so brilliant I looked past the badge, but I did agonize over it.
The Maverick, probably more than any other model Ford offers, probably has the highest number of import conquest buyers like myself. I wonder how many will be back again after a round of Ford level of attention to detail.
tiktokbrainrot
around
91 F250, 20 GLI, 25 Mav XLT
Yep.
I'm sure they'll come back, since despite whatever issues they have, nobody seems interested in making their own Mav. Toyota could do it with the rav 4 platform, RAM has the rampage, VW could make the Tarok......but nothing. Crickets.
ShadowBlack XL440
Robert
Northern Ohio
Thanks!
I don't recall the eCVT transmission having a magnetic plug like the PTU and RDU. I could be wrong but found nothing concerning about the trans fluid other than being below the full level.
ShadowBlack XL440
Robert
Northern Ohio
I’m ready to go. I’d like to squeeze under without lifting my truck - but I might be too “barrel chested”. Sounds better than too fat tbh.
Sounds like we share a similar body physique, I am thankful to have a lift to eliminate that access restriction.
Yep.
As soon as an equal enough option available from another non-domestic brand - probably not that many.
Or they discover they didn't really need a truck that often, despite initially thinking the option of it would be very useful.
Forgot whose SUV back area I was looking at with the owner, and we realized they may have designed in some features to carry 4ft wide sheets, since they would fit. It appears some similar slots to put a 2x4 at the back, and the forward seats down but not flat were the same height. So a level surface, and an auto-open/close rear door that would basically be locked down by pressure when lowered until it hit the wood sticking out, but tie-downs anyway.
