CAUTION Cargo Stop Light Removal
Chief2008
Gouldsboro Pa
Bronco Sport to Maverick Lariat
Don't ask how i know!! I know a lot of us are changing the bulbs in this light to LED The plastic clips that the screws go into are not very good. The clip actually spin in its mounting hole very easily. This makes the screw unable to go in or out. Has anyone had this issue and does anybody have a part number for the plastic clip and screw. At this point it looks like the screw will have to be cut to get it out. Any help or solution or hack would be appreciated. Or the size of the opening hole for the clip might be able to find a stronger one. Thanks in advance. Another 15 Min upgrade turning into a nightmare!!
Quest
If you pull on the lamp while turning the screw with a cordless driver it should walk right out
Don't push on the driver, just let it rotate the screw
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
One of my Ford dealerships techs had the same problem when they replaced the light housing under warranty, so it's not just DYI problem. Just poorly designed, IMO.
EffNo50
Central California
I had the same problem on mine. I think I managed by pulling on the light and wedging the "v" in a a small pry bar against the plastic insert.
Replaced them with these:
https://www.amazon.com/dp/B09VZLRNJY
BK007
BK007
OH
Here you go with some of my idea input and Ai LOL. I used to do bodywork and paint, and I've seen plenty of Ford 3rd brake lights turn into a nightmare over the years.
The Fix: Don't bother with the OEM plastic clips once they spin; the square hole in the cab usually gets rounded off. Use some side-cutters to snip the head off the stuck screw to get the light off, then pop those plastic junk clips out.
Tip: I would also replace the FOAM sealing gasket while you have it off to be safe. A wet headliner is a much bigger headache! Since Ford usually only sells the gasket with the whole light, just grab a roll of 1/4" thick EPDM closed-cell foam tape while you're at Ace and cut it to fit.
Good luck !
Ace Hardware Parts List
ItemQtySize/SpecNotes
Extruded U-Nut4M4.2 or M5These are the metal "speed clips" that slide over the cab sheet metal.
Stainless Steel Screw4M5-0.8 x 20mmPan Head or Button Head. Stainless is a must to prevent rust-welding.
Bonded Sealing Washer4M5 or 3/16"These have a rubber backing to prevent water from entering the screw hole.
Ford Maverick CAUTION Cargo Stop Light Removal 3rd bake light
Tech Tye
Ken
Kentucky
2023 Maverick
Tbone289
I've probably pulled mine out 6 times trying different bulbs, and had no trouble at all with the fasteners or the seal. They just need to be snug for a good seal, you don't have to crank them down.
I second your idea.☝🏻☝🏻
Saves time and any further frustration just replace them.
A bag of 30 for $9.99.
Here's a picture off the Amazon link.
Ford Maverick CAUTION Cargo Stop Light Removal Screenshot_2026-04-12-15-40-43-49_40deb401b9ffe8e1df2f1cc5ba480b12
ice445
Ryan
Utah
24 XLT Tremor
Mine was fine too, but the factory definitely overtightens them from time to time setting one up for failure lol
Chief2008
Gouldsboro Pa
The problem is the whole insert is spinning so pressure is not doing anything. thanks for you suggestions. looks like I will have to cut the screw and find replacement inserts and screws as some one listed.
EffNo50
Central California
Same problem most of us have had. By pressure, do you mean pushing into the screw, or spreading the space between the light and the cab to engage the plastic legs further down? I guess if you can't loosen it enough to get a gap you'll probably need to remove the head of the screw. I'd carefully drill it, if you can keep it from spinning at all.
Medicman14
Kansas
23 Maverick XL 15 Fusion 93 Tempo 74 HD Sportster
I had the same problem. Ford "fixed" the issue under warranty. They installed the same problem parts expecting the issue to be resolved. I ended up buying new nylon nuts and using clear silicon sealer to affix them in place. Problem solved.
Important:
Do not tighten down on the screws hoping to get a snug fit of the cargo/stoplight housing against the roof.
It could Result in a Cracked Housing or Stripped Screws.
Ford Maverick CAUTION Cargo Stop Light Removal IMG20260413135622
It's design is not to touch the roof. There is a rubber gasket underneath that touches the roof.
Good luck,
GB
Soberjoe
Ottawa, Ontario
2022 Maverick Lariat 2.0 ECO
I may be too late chiming in, but if not: grab a small pair of needle-nose pliers; wrap the tips in 1 layer of electrical tape to avoid scratching the Ford-Quality paint; pull the housing away from the roof and grab the spinning little bast@#d with the needle-nose; use your screwdriver to turn-out the screw while holding onto the nut with the pliers; get new nuts from Ford, Part #W718256 S300
(That is the Ford Canada part # - not sure if it is ithe same # in the USA)
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Thanks to everyone posting about this issue. I removed the third brake light assembly today using my handy dandy Chapman set, if you never heard of it they are an industrial machinery serviceman's best friend, and removing them by hand. I did not attempt to use a power screwdriver out of habit. Whenever I am unscrewing something the first time I prefer to use hand tools only, just my preference. But the comments on this thread made me be even more cautious. I replaced the cargo lights with Sylvania Zevo LEDs. Much brighter. I took used oil to Autozone and walked past the light bulbs and saw they had them in stock.
https://www.autozone.com/p/sylvania-zevo-center-high-mount-stop-light-bulb-921zevoled/14493
