Cargo light internal housing is melting/cracking
ctag
1998 Honda Civic, 2025 Ford Maverick XL 4K
Is anyone else seeing this on their Maverick? Tried a forum search and didn't come across anything.
2025 Hybrid Mav
Ford Maverick Cargo light internal housing is melting/cracking 5080
Ford Maverick Cargo light internal housing is melting/cracking 5081
vandeda2024
US
2025 XL Hybrid, AWD, 4K
just throwing this out there ... could it have been a bad molding to start with that you just recently noticed?
Cancunbadlands
Cancun
Cancun
#OMG I never reach the bed of my truck!
ctag
ctag
It could be an original defect, but the way it sits right above both bulbs makes me think the heat from them is melting the plastic.
OEM bulbs, nothing aftermarket, and I don't make a habit of manually kicking the cargo lights on with the button in the cabin very often.
KenR
KenR
DFW
F150
Does not look at OEM Maverick lamp.
vandeda2024
US
I missed that it's both sides. That's interesting.
2025 Hybrid Mav
Yes, compared to my pictures it looks melted.
Turns out it's a common and known problem. Caused by the heat of the bulbs.
Covered on several other sites since at least 2023.
Type in the Google
Maverick 3rd brake light and cargo lights melting.
I changed my bed lights out to LEDs 2 years ago.
23 hybrid
Ford Maverick Cargo light internal housing is melting/cracking 20260217_083206
Pictured below👇 are the OEM bulbs/lamps I took out.
Because LEDs have to be placed in the socket a certain direction. I replaced one side. Then I checked to make sure that the led illuminated before replacing the other side. I had to wait for the OEM bulb to cool down before I pulled it out.
Ford Maverick Cargo light internal housing is melting/cracking 20260217_090829
Carlitos_92
Huh? It looks exactly like an OEM Maverick lamp. 🤷‍♂️
2025 Hybrid Mav
Went and checked my 2023, and it is at least that bad, if not worse. I also don't make a habit of having those lights on every long, or at least so I thought. I'm also on the original OEM bulbs... which look just like those.
As I have said before, the worst part about these trucks is that they are Fords. :facepalm:
Blue_Max
Orlando, FL
I see that on one of mine on my '24. I assume the Florida sun has caused it.
I don't think it is sun damage.
My Maverick sat outside the first summer I owned it in the 110°-117° desert sun. My current picture show no damage. I did change to LED'S in 2024.
Type in the Google
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
I've seen this happen to a few people, but have yet to see a cause. It's probably worth swapping to led bulbs as they do run cooler, they also look better IMO
Ford Maverick Cargo light internal housing is melting/cracking Photo Sep 03 2025, 3 43 36 PM
Tall Hobbit
New Mexico
2024 Ford Maverick XL Hybrid w/ copilot 360
Yes, when I checked found similar, only on the driver's side:
Ford Maverick Cargo light internal housing is melting/cracking 20oirn29
Took a while to understand what was meant by 'cargo light' that comes with all trims, but eventually realized you're referring to the lights activated by the jellyfish launcher.
Mine haven't seen especially hard use or adverse conditions. I try to conserve my invertebrates to extend battery life.
edit: no hard use
