Broken stud on vertical wall for tailgate assist
PCK
Phil
VW R32; Maverick Tremor
Somehow I broke the stud on the vertical wall that the piston tailgate assist attaches to. As they are all essentially the same, do you know if anyone sells just the vertical wall attachment so I don't have to buy a whole new assembly? Or someone has a spare attachment that they can sell me?
BoxxerDad@50
Kip
Lees Summit MO
MY25 XLT BAP XLT HYBRID SOLD MY 2023 XLT hybrid 2023 Lariat,MY22XLT
Not sure I understand? Pictures might help.
shrek
Jon
Alhambra, IL
2024 Mav Lariat Lux FX4, 4k tow
I think they are talking about this :
Think they broke the ball stud off. I am pretty sure that any competent welder could fix it in 2 mins.
Ford Maverick Broken stud on vertical wall for tailgate assist 1750430726150-qa
PCK
Phil
Not quite. The circled part goes on the tailgate. I took a photo but have been late in attaching it.
Where would I find a competent welder?
Ford Maverick Broken stud on vertical wall for tailgate assist PXL_20250619_195710279.MP[1]
f1jim
Pacifica, CA
2025 Maverick Lariat
Mine broake in exactly the same place 3 months after purchase. I bought mine on Amazon from a company called Klutchtech. After several emails and a bad review from me they finally sent me a new complete kit with all the pieces. Took 2 months but I got it and they did make it right.
I now have enough pieces for a backup since I epoxied the broken piece together. I have no hope it would last long if I needed the epoxied piece but it would probably be as strong as the original piece, judging from my examination of the the broken parts.
f1jim
shrek
Jon
Alhambra, IL
Nope, pretty sure the image below is the tail gate (and it has the half moon cut out) the piece I circled is the part that is broken in your picture.
BTW, the the piece that you have installed is not installed exactly correctly. Notice that it is not straight up and down? Its angled too much towards the rear. If you get it welded or you get a new piece, ensure that it is straight up and down. Will prevent undue stress on the piece in the future.
Ford Maverick Broken stud on vertical wall for tailgate assist 1750435972895-k6
Manollo3
Mario
South East Texas
Jeep Wrangler, Honda Africa Twin, TW200, 2025 XL Hybrid, AWD, 4K
You are better off just to order a new one off Amazon. They are less than 20 bucks.
WOW, I would think checking around at local automotive repair shops, etc. Especially mom/pop independent ones, drop in and ask around who locally does that. just a thought
jesemd
PA
Forester
The photo shows a bad weld. Usually a local welding shop will sneak in little repair jobs like this for beer money and you will end up with a stronger piece when you are done.
BoxxerDad@50
Kip
Lees Summit MO
Don’t buy knock offs
I did once
Dee see is the best
f1jim
Pacifica, CA
Just to clarify, the part circled in red is the proper piece to use as the upper bracket. In the photo he provided it is slightly askew and not straight up and down as required. Is this the reason for the break? I think not as that angle should not affect the strength of the weld regardless of the angle.
It is clearly the weak point on this device.
By the way, on Ebay I have found the same complete kit for $9.95. I ordered one as at that price it would give me more confidence than my epoxy fix. It also is alreasy painted black to match my blackout package.
From my evaluation they are all coming out of the same manufacturer, just marketed under different names.
f1jim
shrek
Jon
Alhambra, IL
It Does affect the operation, if the part is not correctly installed straight up and down. Ask me how I ruined the tailgate cable on Drivers side.
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
I just so happen to have an extra black painted one. I replaced the Dee Zee piston because 1. I didn't like the Dee Zee logo and 2. the piston was gurgling loudly on opening. All the pistons are basically the same, manufactured in China so I bought an inexpensive kit off Amazon and just replaced the piston. I will send it to you for the cost of shipping.
GlennBeer
Glenn
Manteca, Ca
24 Maverick Hybrid Lariat, 04 SSR
I don’t know how you managed to break it at all. The cable should have stopped the tailgate from putting that kind of load on the ball.
shrek
Jon
Alhambra, IL
It didnt "break" the cable. I had said I ruined it. It just tore the rubber out sheath off. And it started to rust. It was due to me not having the tailgate latch bolt (with the TORX) tightened enough and the bracket moved; and that allowed the cable sheath to be worn away by the ball socket keeper attached to the bed.
