Croley
Muskoka
F150
Some water intrusion during car washes, but it is minimal.
Have some difficulty putting the prop bars up, but rarely needed.
Can’t beat the price for a solid tri-fold tonneau.
Some foam pieces are losing their adhesion, but haven’t fallen off yet.
Would buy again.
Thanks for the info. mice to know your opinion from real experience.
skinnyboy
Andy
Ontario, Canada
My 2023 Maverick has just arrived in Toronto and I'm looking at cover options. How happy have you been with your Bison? How do you like the fit of it? How "waterproof" is it?
Very happy with it, would absolutely recommend it. Fit was great. There is some water intrusion, but I don't know how you could have something like this seal 100%. I saw a Ford tri fold on a Mav at the dealer, looked exactly the same aside from the decal.
Cheers.
Ponyprez
Kevin
Southern New Mexico
1965 Mustang 2+2, 2023 Mach E, 1990 Mustang 7UP Convertible, 2023 Maverick,
Benilla
Edmonton
How is everyone's Bison tonneau holding up? Mine's starting to rust after less than 1 year, I've emailed them about this, we'll see how they respond
Ford Maverick Bison Tonneau Cover Now Available For Maverick PXL_20230409_002005930
MortyHooper
Vancouver
2007 Matrix
It rained heavily overnight right after I installed it, no water inside. Haven't driven in the rain yet.
Did you install a seal along the sides or along the bulkhead? I managed to get a cover used tonight (guy upgraded to a cap) and he provided some but just short pieces of the seal material. I might order some longer strips on Amazon.
edit: seems like I should buy some, if anyone has a brand of seal they have had good luck with please share the link, thanks!
son of a ..sven
Oregon
2023 Hybrid
Web site says they have a video of the tri fold soft cover, but only show a hard trifold installation. Is it the same installation process/rails/etc?
skinnyboy
Andy
Ontario, Canada
I didn't add the provided seal along the bulkhead, the rubber flap seemed to do a good job on it's own. The only spots that might be worthwhile are the two front outside corners where the seals taper down to the bulkhead. I didn't do them either, figuring the tailgate has lots of gaps that rain will get in regardless, and it's still a truck bed :).
Cheers.
skinnyboy
Andy
Ontario, Canada
Gave those spots a shot of Krown/Rust Check stuff after the winter. Just the nature of the beast in the rust belt, unlikely to get Chinese parts like this e coated from the factory.
Cheers.
Benilla
Edmonton
Cheers.
Yup that is exactly what I'm going to have to do, I checked with them and this isn't covered by warranty. I saturated it with WD40 as a short term solution and cleaned the area as best as I could so that should last a month or so. But 100% after this coating wears off, I'm getting the Rust Check.
MortyHooper
Vancouver
2007 Matrix
Cheers.
Good call, I’ll probably coat it all prior to install.
Zolutar
Sea to Sky, BC, Canada
23 Maverick Lariat Lux Hybrid, 21 Bronco Sport OB+
Looks like Bison hard tri-folds got restocked!
I put in my order, can't beat the price.
TRUCKHEF
SOCAL
22' Ford Maverick XLT
Can you open and close the tailgate while this is down?
jblade44
WINDSOR, ON
Maverick XLT with Lux
I installed mine yesterday without the drain tube for now. I have factory drop in bed liner didn't have the cutouts. Can I drill holes and get the correct spot or do I need to remove the sides on the liner?
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
The hole locations are marked on the back of the factory liner sides, so you're going to need to pull them out and drill them from the back side.
