Battery Saver mode
colt
stephen
orange park ,fl
2024 maverick hybrid
I have a 2024 Mav Lariat hybrid and it almost constantly when in driveway is in that bs mode. Cannot start it from my phone , at night when I get in it no interior lights come on. Has Ford done anything to fix this prob? Can the SOC be raised to 100% instead of80%. permanently? I should not have to put up with this kind of problem. I only have 9600 miles on vehicle. I know if I drove the truck on longer trips it would possibly alleviate the problem but I should not have to do that! It goes in shop for oil change next week let us see what the dealer says.
shrek
Jon
Alhambra, IL
2024 Mav Lariat Lux FX4, 4k tow
Take a look at the bottom of this thread. (Literally hundreds of threads on the exact same thing.)
This is the Whole reason I will never get a hybrid. My 2024 Lariat 2.0 has had its issues but never battery
As far as I know Ford has not done anything about the battery drain or charging problem that some hybrid and to a lesser extent the EcoBoost have exhibited.
https://www.mavericktruckclub.com/forum/google-search/?q=EcoBoost+battery+problems
There are workarounds and things that can be done to increase the battery charging including using the FORScan app.
All things that the owner should not have to do to have a reliable vehicle.
Good luck
Dennis Lucker
Dennis
O'Fallon Il
2024 Maverick Lariat Hybrid
My 2025 Maverick has had the same problem since I got it. It got to the point that it was always in battery saver mode. Every time I had the oil change I told the deal and they said the battery fine. This last time I said if the battery is fine then there is something else wrong. They performed a software update on abs module and accm and cleared the codes. It has been two weeks now and it still has not gone into battery saver mode. Keeping my fingers crossed.
camdids
Martin
East Massachusetts
2026 Maverick XLT Hybrid
Have been taking in all the fun things of the Maverick since getting my new XLT Hybrid in September. I have an August Build 2026. Should I expect this Battery Saver Issue at some point, or can I assume it has been finally sorted by the time mine was built.
dsr500sl
ds
oregon
24 maverick
My 2024 sits for a week or 2 between drives, It really annoys me in the early morning when I open the door and have no interior lights until I start the truck in the pitch black. This is a lesson on a Ford engineer just out of college with no life experience who programs things not because they are needed or wanted but just because they can program it that way. Hey Ford - how can my interior lights put a draw on the battery when they are off while the truck is sitting there not being used ? (can you tell this bothers me everytime it happens ?)☹
shrek
Jon
Alhambra, IL
Just think..... If you have a hybrid; And a pregnant wifemate. And the "Time Comes" do you trust it to get her to the hospital? Or do you cross fingers and "HOPE" it will start and go where you need it to go. And NOT go into "LIMP" and stop.............. NOT me. FORD has fudged this all up. NO way would I own a Hybrid Mav. I regret owning an EcoBoost.............. So many issues. Tranny, Drive shafts, PTU....... I can keep going. All before 52K Miles. I still own this turd. But I ordered a 2027 Ranger. Will be trading it in when my Ranger Gets built. I already know the Tranny is an issue with the Ranger....... But. It beats an Import.
Waterick
Laurens county SC
I would assume nothing, at least give it the cold winter months and maybe even a few more. Some people have never had a problem even with early editions. In my case on my '24 (a Nov '23 build) I made it through the first SC Winter, but am now on my third 12v battery.
My 2022 hybrid xlt had it OEM battery die at 4 years 2 months. I called Ford dealer ordered and paid for Ford AGM installed in my driveway. Price was MSRP on battery plus remote service of $59.50. Of course there was the "supplies add on". Total ticket was $306.27 BUT TECH cleared the 15+ error codes that tripped up when I turned key on with a 6.5 volt reading on my dash voltmeter. Tech then, updated truck with whatever changes new battery required and possibly the newest update which showed to be active the same day ford released it to dealers. In any event since that battery was installed the dash cig style voltage monitor instead of showing battery voltage 12.1-12.4v for a half second and then the 14.7 dcdc output NOW shows the 12.7 v battery for half a second followed by 13.2-13.7-14.2-14.7 in steps or whatever the max dcdc will be based on need. I take this stepping up of the dcdc voltage to truck checking things as they are turning on. So possibly a programming change??? Maybe a fix??? Cross fingers.
Dennis Lucker
Dennis
O'Fallon Il
My 2024 Maverick has had the same problem since I got it. It got to the point that it was always in battery saver mode. Every time I had the oil change I told the deal and they said the battery fine. This last time I said if the battery is fine then there is something else wrong. They performed a software update on abs module and accm and cleared the codes. It has been two weeks now and it still has not gone into battery saver mode. Keeping my fingers crossed.
2024
There is no sorting out to be done. It's exactly the same.
The purposely designed charging strategy will result in an undercharged battery that will slowly but surely sulphate and drop to a low battery charge causing battery saver changes and eventually Deep Sleep Mode for the modem, preventing remote access features.
Unless you literally drive for hours a day.
Then at least you might keep it at the top of the potential charge for longer.
But not the 4-7 years one might be used to older vehicles having batteries last.
Throw in some known potential intermittent battery drains, that are not good for an already undercharged battery - that'll shorten the life even more.
Your 26 should be covered for the 2 big known ones tracked down on the pre-25MY.
Doesn't mean new ones might not crop up though - got a bunch of computers in there!
I'm sure they charged the battery up too then, and for an AGM and only 2 weeks that ain't bad.
Oh - fine to warranty replacement is 40% SOC or above - that's what they meant.
But maybe you did have those intermittent battery drains hit during the 60 min going to sleep time - so while it never finished your battery off, higher drain didn't help for that time.
That would have been proved out by having the Ford app notice about DSM happen within that hour of last truck turn off.
Drive with your parking lights on if the headlights aren't due to darkness - maybe you'll help get it to full charge if you drive enough - minimum hour daily would be hopeful!
There is no SOC figure to adjust - what you heard was myth.
Gotten an AGM yet thru warranty?
That's your best bet, but not a final solution if you don't drive enough.
JDMaverick
North Texas
Maverick Lariat
I was starting to have some deep sleep issues so when parking would start the ICE and extra charge the battery. Some will say that’s waste, because if it needs a charge it will do it, but if the car is turned off it won’t. You can watch it charge on that one screen and will tell when it’s full. I had 32.5k and it was going out of warranty soon so I took it in for an oil change and they said the 12 volt was weak and replaced it. Both old and new were AGM batteries.
