2023Area51
Midwest
2023 Maverick XLT Hybrid
Hello MTC,
I recently took apart my Maverick and decided to BAP my headlights. This is a very tedious process, but if you are patient, it is something that you can do. I hope this post contains information that will make more forum members more confident in BAP'ing their headlights, as I did.
Before going into the process, I will say that this is a tedious process. There is lots of patience required to separate the headlights. I am by no means a professional mechanic, but I have experience rebuilding cars.
The first step you will need to do is disassemble the front end of your Maverick. Several different videos discuss how to disassemble your front end. I found MrBoom_5.0's video very helpful.
MrBoom_5.0 Front End Disassembly Video
I did not take the whole front end off, just enough so I could access the headlights. You will need to remove the amber turn signal bulb (1/4 turn) and the electrical connection to the headlight. There is also a white piece of plastic that holds the wires to the headlights that will need to be removed. It should look like this when all of this is done:
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8722
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8724
Now for the fun part. With the headlights removed, remove the six screws. You will need to soften the sealant inside the headlights. The most popular method is putting your headlight into the oven. I watched a few videos detailing this method before attempting it myself. Knowing my oven does not heat up well, I settled on 280 degrees Fahrenheit for 15 minutes. If my oven were more efficient/warmer, I would do 270 degrees. I did not feel comfortable going much higher than 280. I put a piece of parchment paper on a baking tray to help protect the headlight (I did not do this initially, as you can see in the photo below). I would advise you to put something down on the bottom grate.
Preheat the oven without the headlight and pop it in once it hits your temperature.
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8723
You will want gloves to remove your headlight and a flathead screwdriver to separate the lens. My best advice is to separate the headlight from the outer lip first, then the inner lip. Remove the plastic tabs holding the headlight together. Pay close attention to the corners. This is where it can get tricky. If you feel things are getting difficult to separate, put your headlight back into the oven. I did this on my first headlight two times (10 minutes each time I put it back in) and only once with the second. Once you separate the outer lip, you can work on the inner seal.
With a bit of patience, your headlight will separate.
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8738
Five screws are holding the plastic trim to the lens. Separate that and put it into a tub of ZEP Degreaser. I would recommend getting two gallons.
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8739
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8774
I would recommend 30 minutes per piece. Once all the chrome has been stripped, wash the ZEP off. Double-check to make sure all the nooks have been stripped. Let the plastic dry, and once it's dry, reassemble.
Before you seal the headlight up, make sure the inner lens is not dirty. I set my lenses down so no dust would get into them. I would advise you to put the housing back into the oven to make it pliable. I put some waterproof sealant in the headlight to help protect it.
Once that is done, pop them in your Maverick, bolt it all up, and you have BAP'ed headlights!
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8776_2
Ford Maverick BAP'ing Guide for DIY Black Appearance Package - Front Headlights Edition IMG_8779_2
I hope you all found this helpful. The process took me two days, mainly due to my lack of planning and timing. This is something that could easily be accomplished within a day. It's not difficult to do, but it is tedious.
TacRunner
Rob
Springfield, Louisiana
2022 Ford Maverick Lariat Hybrid
Thank you for this - it’s awesome and I’ll have to make this work for my Mav.
One quick question, any differences when trying this with lariat headlights w/ daytime driving led bar?
subiefiles
Westside
MY23 Mav Lariat (+lots of Subarus)
Concentrated Zep just strips the chrome off? Interesting. You could just spray the insert piece flat/satin black though too right?
Definitely a cheaper process than trying to source actual BAP headlights!
rclee
Rob
Dayton Ohio
I have one question, are the LED headlights serviceable (replaceable) when you have taken it apart that far? I only ask because, they say the headlights must be replaced as a whole unit. I am looking down the road as I plan on keeping this truck for a while.
inline_five
2023 Hybrid XLT
Each headlight is $1200 and you are putting them in an oven and 100% for sure killing the warranty.
This is a super cool project but WOW what a risk if/when the LEDs go because they were heated to 280°.
MikeNg
Michael
Alameda, CA
Spray paint does not attach well on chrome surfaces. When retrofitting headlights, all the chrome has to be stripped off before painting.
thev8man
Hello MTC,
Booyah 👊🏽 😁 👍🏽 🇺🇸
Did you paint the bezels or Plasti dip them?
2023Area51
2023Area51
Midwest
I am sure there will be some wires you will have to watch out for, but the LED strip in the upper section is just another piece of removable plastic (just a few tabs). If I wanted, I could have taken that piece off on my XLT to make it non-BAP'ed.
2023Area51
2023Area51
Midwest
I would ZEP them. There are too many crevices for you to really get a good spray. I'm also not sure if the paint would stick.
2023Area51
2023Area51
Midwest
It looked like the housing was serviceable. I did not take that section apart, but I could not imagine it wouldn't be. I'm guessing they are suggesting replacing the whole housing since it would take awhile to split it apart.
2023Area51
2023Area51
Midwest
Definitely don't disagree with this. It most certainly is a risk.
2023Area51
2023Area51
Midwest
Booyah 👊🏽 😁 👍🏽 🇺🇸
Thanks!
I used ZEP degreaser. It strips off the chrome plating on the headlights. I picked it up at my local Lowes for about $12 per gallon.
thev8man
Thanks!
Booyah 👊🏽 😁 👍🏽 🇺🇸
Thanks , I just thought I was missing something.
FJM
Frank
Upstate NY
Hello MTC,
I’m good at baking meatloaf but headlights are out of my range. 😂
K5Blazer
Colorado
2023 Maverick XLT
You are a brave man.
