Atkinson motor and fuel octane
Rkbrumbelow
Robert
Cedartown, GA
HCH2, Hybrid XLT on order
It’s not a true 13 to 1 because the compression stroke is bleed off in the first 20-30 percent back into the intake due to the valve being open. I would guess it’s true compression is more like 8.5-9.0. The negative to this setup is lack off low end power which made up for by the electric motors instant torque.
12.7:1 is considered ideal for HP production but here is a video on how the Atkinson cycle works
dvibs07
dvibs07
Oregon
Jeep Wrangler Unlimited
We know what your going to put in your bed cubby.......Hemp :)
No sir, industrial hemp is very sharp and rough. It would best be suited in our FLEX BEDS®.
Ronaldo
Ron
Los Angeles
71 bronco, 67 conv Mustang, 93 RX7 R1
Yes this explains it exactly, it’s compression ratio is 12 to 1 but it actually is 10 to one Because the valve is open the first 20-30 percent. Look at it like this on a regular none direct injected motor with 87 octane the compression is about
8.5 -9 compression ratio. So the Atkins motor true compression ratio is like 8.5 -9ish.
Rkbrumbelow
Robert
Cedartown, GA
I was expanding your excellent answer, not trying to contradict it.
DesertSweat
Arizona
Ford Maverick Lariat, Honda HR-V 6spd
We talk a lot about compression ratios in this which is absolutely true, but you can't forget the timing curves based upon load, RPM, IAT, etc, since timing stresses the fuel a lot and impacts efficiency.
All cars will have a base map of timing created using the intended fuel (I think we are fairly confident that the intended fuel for the hybrid is 87) in fairly ideal conditions. Basically it's just a 2 matrix based upon load and RPM. Then there will be tables that generally multiply, or add or subtract based upon certain parameters. Like if you have really high air intake temps or the knock sensor starts getting pre-ignition, or fuel trims are way off, the motor will pull timing.
The more timing the better. But in my experience, I haven't seen maps that increase timing and try to get better efficiency. Because that is tough and requires instrumentation that engines don't come with. (think individual egt and wideband O2 sensors for each exhaust bank). The only real learning I see is in STFT, and LTFT's. Which are fuel trims based upon closed loop operation. ie. the ECU is looking at the MAP of MAF sensor in relation to the wideband O2 sensor and learning how to hit your desired lambda - AFR, because fueling is always a moving target based upon many variables.
TLDR: intended fuel is 87 and the motor would have been tuned using that. You shouldn't see a performance or efficiency increase using a higher octane since all maps are tuned to take away timing.
On the power question, that's a bit more complex, I could speak to the ICE side, but I think there's more potential on the battery motor side. But regardless of either, the ECU needs to be cracked, and software to modify to make any significant gains. But there probably is not enough interest, so there won't be a lot of support.
stick
2021 Jeep wrangler 4xe; 13 vw gli; 21 maverick xlt
With an Atkinson engine the 13:1 compression is mostly theoretical. The intake valve is kept partially open at the beginning of compression so some of the A/F mix is pushed back out of the cylinder. Therefore the total compressed volume (and effective compression ratio) is lower allowing operation on regular octane. The advantage is this allows the post-combustion expansion to utilize the full stroke for maximum efficiency.
Octane rating, on its own, does not produce more power. It simply allows higher compression. So an engine that does not take advantage of this through high compression ratio or forced induction (turbo/supercharger) won't make more power. Ethanol, however, has less power density than gasoline. So regular octane fuel without ethanol will produce the highest efficiency. Availability of that will depend on where you are. Often only Premium fuel is available ethanol-free and if the cost difference is greater than the increase in efficiency it's not worth spending more.
Higher the octane, lower the energy in the fuel, but more chains are 8-carbon, which is the most stable molecule chain in gasoline. hence, octane rating measure percent of 8-chain molecules in the fuel. Total waste to use if your car can not use it. Cars with variable valve timing can advance the spark to increase power utilized on each stroke. Low octane fuel in a advanced timing engine will cause knock, which is early combustion = engine damage. Most modern cars have knock sensors that automatically retard timing if knocking occurs. This engine is set up to have no low end torque, so the torque curves of the electric fills in and keep the torque flat. The electric pulls early and the engine shows up later. thats why the combined torque numers dont seem to add up
Don't know if they still do it or if they're more confident in the knock sensors these days but older Fords used to have a bypass plug under the hood that you removed and it retarded the timing even further if you were somewhere running 85 octane or less.
dvibs07
dvibs07
Oregon
It’s not a combined torque, it’s just the torque from the engine I believe on the specs page
stick
2.5L/162-hp/155-lb-ft Atkinson-cycle DOHC 16-valve I-4, plus 126-hp/173-lb-ft electric motors. Yep, they only publish the combined HP. I think the line of thinking still applies. electric on the low end; engine comes to the party later in the revs. I would like to see actual HP/torque curves
Peps
New England USA
2020 Volvo XC40
regular gasoline on both the 2.0 and 2.5 hybrid.
for the escape these are the EPA stats with the type if gasoline.
Ford Maverick Atkinson motor and fuel octane 67D9C9EF-A492-44C8-AA94-9932395F925C
dvibs07
dvibs07
Oregon
I hope the hybrid engine surprises with torque. The most utility I could get out of my engine would be slow crawls up hills and a lot of torque to get over obstacles.
Rkbrumbelow
Robert
Cedartown, GA
C-C is ~ 80kcal/mol, H-C is ~ 100kcal/mol, ΔHf = -393.5 kJ/mol CO2(g), H2O(g) = -241.8 kJ/mol
H2O(g) if anyone wants to do the genchem maths, oChem, please take into account strain and electro negativity. qChem do the same but account for spin and stabilization as well as what the energy well looks like across the temp range. pChem don’t do any of that: let’s light the bitch and see what happens in a fully closed system ;)
Shecster
North America
1930 Model A Ford - 1971 Ford Maverick
May I add a question to this thread? Does octane go down with aging, stored/unused fuel?
Yes it will. Fuel loses its flash point over time and leads to absorption of impurities I.e moisture.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
H2O(g) if anyone wants to do the genchem maths, ...
The EPA has defined the energy content of 1.0 gasoline to be 33.7 kWh. I think that's E10, because...
Based on energy/kg, I get 35.24 kWh for 100% gas, 33.25 kWh for E10. Bottom line is the tank holds about 500kWh of energy. Best we can do is waste 60%, so there's 200kWh usable energy in the tank.
oljackfrost
Minnesota
Yikes! I haven’t been so overwhelmed since high school algebra!
