I’m looking for someone with intimate knowledge about engines to answer a couple questions for me. I’ve been researching Atkinson motors and learning about how they work. I’ve found that the Atkinson motor used has a compression ratio of 13:1 which is pretty high. So I would think premium fuel with a higher octane would work better. However, reading about the Atkinson motors I discovered that lower octane is recommended because the ignition rate works better with the natural cycle. So…
-Would running a low octane fuel with more ethanol produce a more efficient engine?
-Will premium work better or get more power or will it just knock?
-Any ideas to get more power out of the hybrid engine?
