Maybe?????only problem I have with the stock antenna assembly is its size,my previous vehicle was a 21 escape and it had a much smaller antenna assembly and no rod sticking out. looking at pictures the connector looks to be compatable but I found some info that the escape uses the rear window defroster for AM/FM reception but I have not yet confirmed that data. I have discovered that installing a stubby antenna in place of the 13" stock one does not apear to effect FM or AM reception but it does greatly reduce range of the fob. you have to get much closer to remotely lock or unlock or start thasn you do with the stock long antenna rod.
Fixing Poor Reception
- Tighten or replace the antenna mast: Unscrew the exterior antenna whip. Clean any dirt or corrosion off the threads, then hand-tighten it firmly back onto the base. A loose antenna breaks the circuit and kills signal strength. [1]
- Check the antenna base and ground: Inspect where the antenna base mounts to the vehicle body or roof. A rusty or loose grounding connection starves the signal. On some models, you may need to access under the headliner or interior light housing to tighten the mounting screw and clean the grounding washer. [1, 2, 3]
- Inspect the coaxial cable: Check the back of the radio receiver or the antenna lead-in cable for loose plugs, kinks, water damage, or corrosion. [1, 2]
- Isolate electronic interference: Aftermarket phone chargers, LED headlights, dash cams, or portable power adapters plugged into 12V sockets often create electrical noise that blocks weak AM/FM signals. Unplug accessories to see if static disappears.
