AGM for Hybrid
Silver23
2023 Ford Maverick Lariat
Can anyone confirm what AGM will fit correctly (or at least close) in the hybrid. I can't find any group 99 or T4 in an AGM.
TIA
BlueSpec1
Gene
TIA
I Installed the ACDelco LN1AGM battery in place for Ford's OEM BXT99RT4-A that was in my Maverick hybrid.
The LN1AGM weighs 32.5 lbs, the BXT99-R is 27 lbs.
They're nearly identical physical size.
The LN1AGM has vent holes at each end of the battery for connecting the vent line and comes with a plug for the unused vent hole at the opposite end of the battery.
Ford Maverick AGM for Hybrid LN1AGM Installed - Side View - 2023-11-22
Silver23
Silver23
this little guy correct?
https://www.summitracing.com/parts/...W1gD2V129Ydob19I2jhg7c_1BPTDD5KcaAi23EALw_wcB
BlueSpec1
Gene
Oscarcat
Eric
Encinitas California
TIA
I just learned what an AGM battery is! Gotta love this forum. Rhetorical question: Why didn't FoMoCo include it on hybrids where there are numerous complaints of 12v battery failure? [Cost, I know] :)-
rd4440
Michael
San Antonio Tx.
2022 lincoln aviator, 2023 Ford maverick
Brought ac-delco agm battery today at xl parts in san antonio tx. Price $213.44+$18.00 core+tax did not won't to order online. Install took little over an hour took my time here is picture of what tools I used just like earlier post fit just fine. 10mm socket and magnetic thingy for battery lower bracket to put back once new battery was in place. Thanks BlueSpec1 I have been wanting to replace this battery in my Hybrid maverick for some time now. Have had the truck for 10 months now everyday deep sleep mode hope this helps.
Ford Maverick AGM for Hybrid 20231218_170842
Ford Maverick AGM for Hybrid 20231218_172517
Ford Maverick AGM for Hybrid 20231218_172733
Ford Maverick AGM for Hybrid 20231218_175725
Ford Maverick AGM for Hybrid 20231218_175753
stretch119
Jordan
Ohio
2022 XLT Hybrid
How long have you had your AGM installed?
Have you had any deep sleep warnings since you installed it?
Did you need to do any reprogramming with Forscan to enter the new battery specs?
Any other tips that I should know for swapping an AGM into my maverick?
ShadowBlack XL440
Robert
Northern Ohio
If I am not mistaken, I think there are different charging programs that needs to be changed in Forscan per the battery type.
BlueSpec1
Gene
The AGM has been in the Maverick for just month and a half.
No Deep Sleep on Maverick and Escape PHEV.
For Forscan, I just did what I did in my Escape 13 months ago since that seemed to work good enough.
Battery to AGM.
SOC Target to 95%
Battery Type close in Amp Hours to the LN1AGM's Ah rating.
BMS Reset.
Ford Maverick AGM for Hybrid Maverick 2.5L Forscan - AGM, 95% Target SOC, Varta 52Ah - 2023-11-23
I don't put on a lot of miles as it's just short trips around town, so I charge my batteries twice a month.
Ford Maverick AGM for Hybrid Maverick 2.5L 12v Charging 14.62v - @1709 2023-12-30
Maverick 2.5L with the AGM today around town:
Forscan Lite Live Data for 12v Battery and Hybrid's HVB from BECM
Ford Maverick AGM for Hybrid Forscan Lite - BCM 15v, 7A, 75% SOC @1156 2024-01-06
Ford Maverick AGM for Hybrid Forscan Lite - BCM 15v, 4A, 77% SOC @1226 2024-01-06
Ford Maverick AGM for Hybrid Maverick 2.5L AGM Chart - 15.2v @1219 2024-01-06.PNG
Ford Maverick AGM for Hybrid Battery Monitor - Bolt 12.90v, Escape 12.50v, Maverick 12.85v - @1409 2024-01-06
Escape's H6 AGM battery Forscan from Dec 2022:
Ford Maverick AGM for Hybrid FORScan Escape PHEV - AGM, 95% Target SOC, H6 Battery - BdyCM Module - 2023-01-02
stretch119
Jordan
Ohio
2022 XLT Hybrid
Battery to AGM.
SOC Target to 95%
BMS Reset.
Battery Monitor - Bolt 12.90v, Escape 12.50v, Maverick 12.85v - @1409 2024-01-06.jpg
FORScan Escape PHEV - AGM, 95% Target SOC, H6 Battery - BdyCM Module - 2023-01-02.png
Thanks for sharing all those details. I’ll plan on ordering a Forscan adapter so that I can use the same settings as you.
It’s unfortunate to see your Escape SOC getting down around 50%. Hopefully that’s not a sign of an issue.
BlueSpec1
Gene
Escape wasn't driven last week, backed in & out of garage, lots of door open/closing while I installed front & rear dash cam in it.
The battery monitor app SOC% tends to not line up with SOC charts for AGM type batteries.
Ford Maverick AGM for Hybrid Battery SOC Chart - AGM, FLA
Two Week trends/readings:
Maverick 2.5L LN1AGM
Ford Maverick AGM for Hybrid Maverick 2.5L AGM 12-23 to 1-6-24 - Chart
The Escape and Bolt sit for 2 weeks a month. I swap them out for driving.
Escape PHEV BAGM48H6760:
Bolt EUV LN1AGM
stretch119
Jordan
Ohio
2022 XLT Hybrid
Bolt EUV LN1AGM
Fascinating data! Thanks for sharing.
This gives me hope that installing the AGM battery and using your Forscan settings will resolve my deep sleep/dead battery issues.
Hkak45
K
Cody, WY
2022 Maverick Ecoboost
Any updates on if your truck has had deep sleep since installing this back in December?
