commadorebob
I like the idea. Like most of the feedback, I think it would look better if the wires were hidden. Maybe routed through the side mirrors as there is already a wire bundle going to the mirrors already. Would require drilling into the mirror, but even routing out the front, bottom of the mirror would look better than coming out the door like that.
Dad
to follow up on this, the correct thing to do would be to remove the mirror which should be possible by pulling the door panel including sail panel, and wiring through the existing bundle into the door.
a second strong suggestion would be to use heat shrink tubing and solder connections. it's especially important on anything under the hood. if heat, age or anything else causes your electrical tape to fail and presumably your twisted wire splice is exposed, you could have a short which at best will blow a fuse and at worst will start a fire.
that said, I've seen YT videos of 'professionals' install off-road lights that use a 40A circuit - way more than your LEDs I'm sure - and do what you did.
Good advice. I'm curious to see if you have a mind to tackle this mod and if so, would eagerly await your install post. To be clear, no sarcasm intended. Genuine interest.
Maverick2023
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
That bundle of wires appears to be getting very badly pinched. It needs to be routed a different way, because with enough damage, it can short out and be a fire hazard.
You can simply drop it down the side further into the fender
Bad angle I guess but it’s not being pinched at all. I will find a better way to route and package the wires with more electrical tape. Thanks for the feedback.
Maverick2023
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
I will leave this to the next person. As for me I’m ok with having the wire hanging out of the mirror like that. You won’t be able to see the wire on the mirror at night anyway so .
Dad
This is the MTC doing its job of advising, making suggestions, and helping members.
Barracuda340
Abilene Tx
This is a great mod! I added turn signal capability to my side badges, but I'm impressed with your mirror add on. I'm hoping you'll share what you used and how you attached it to the mirrors.
That's a cool idea. I'm looking into that as well. I have some honeycomb aluminum mesh. I plan on cutting out the grilles on the fenders, and attaching the honeycomb. I was thinking of attaching turn signals in there. The mirror ones are cool too. A lot of wire hiding for sure.
Maverick2023
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
so another question i have for you experts is, do i need a load resistor for the turn signal wires? As it stands, I'm not getting hyperflash with the turn signals on the mirrors and I'm tapping these wires to the stock turn signal light connector in the front. I do have a problem with hyper flashing when connecting the stock tail/brake light connector to these lights. The yellow turn turn signals get hyperflashed like they trying to send out Morse codes. In case I'm getting chewed out by the MTC's police for not using a load resistor on my LED lights, I have already ordered load resistors from Amazon and waiting for the weekend to install.
Dad
Using the side badges as is with just a minor modification is an easy way to get side turn signals. There are a couple ways you might consider without using the mesh unless that's the look you want.
Here's the link to my modification. Inside the thread you'll find a post from another member who did an even simpler turn signal modification which I like very much. Check it out if you haven't already.
https://www.mavericktruckclub.com/f...ult-video-night-video-added.27369/post-582187
Barracuda340
Abilene Tx
That's exactly what I want to do. I still want to cut the fake vent center out and put honeycomb mesh. Going for the "look". Thanks!!!
  • Love
Reactions: Dad
Dad
You're very welcome. I'm excited to see the outcome.
Maverick2023
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
Added front and rear turn signals. Decided not to attach to the rear bumper since I couldn’t tap into the lighting wires without getting hyper flashing even with load resisters. I know some of you hate the exposed wires but they don’t bother me. For now the signals can be seen from the front and rear and they are also doubled as White DRL and red looking from the rear.
Ford Maverick Added sequential turn signals and DRL to my side mirrors IMG_8629
Ford Maverick Added sequential turn signals and DRL to my side mirrors IMG_8628
  • Like
Reactions: Dad
Barracuda340
Abilene Tx
I am thinking of how I want to wire mine up. Do I go for the always on clearance light, or the only on when flashing auxiliary turn signal.
check post #13. that's one way to do it if you want it exactly where the OP has it, but without exposed wires.
Barracuda340
Abilene Tx
YuI*uh km(*3
Oh there wont be any exposed wires.
