54 1/4” divider board for truck bed
Ford Build
Missouri
Chevy pickup
Rather than using a heavier 2x4, I used a 1 inch board and wood glued a small piece of the same board at each end so it fills the same space in the slot as a 2x4. I have 3/4” more of bed space on the side with the spacers. If the glue does not hold up, I will use wood screws.
TedTX
Ted
San Antonio TX
Clever, thinking. could due same with plywood and gain more space back...
RLmesc
Randy
Dubuque, Ia
18 Kia Sportage, 05 Porsche Boxster S, 85 Kawasaki
I did the same with PVC boards. I sprayed Berliner on it and used hinges to make it easy for removal and storage
Ford Maverick 54 1/4” divider board for truck bed IMG_4361
Ford Maverick 54 1/4” divider board for truck bed IMG_4362
WJOHNM
New York,LI
I did the same thing, I used 1x10 glued and screwed end strips to take up the space and painted it flat Black. Much easier to lift out if I need the full bed than 2x6. Also added 2 cheap draw pulls on top edge to pull it out when need .
Hot Runr Guy
West Chicago, IL
As long as we are on this subject, how many of you are cutting a custom "height" to match the top of the wheelwells, to provide support if carrying 4x8 sheets? With my bed mat in, I need a 6-1/2" tall board.
HRG
Krischievous
Kristen
Lehigh Valley, PA
2023 Ford Maverick XL AWD Iconic Silver
Finally added some in, it's not pretty but happy to have a place for groceries!
Ford Maverick 54 1/4” divider board for truck bed 1000015131
WJOHNM
New York,LI
I did the same thing, I used a piece of shelfing 1'" by 10" and 2 strips of fir strip on ends to take up space its half the weight of a 2x6. A little flat black paint and a couple of cabinet handles on the ends and its a breeze to remove when I need the whole bed. I used screws and glue on the ends.
Gamma500
2022 XLT
HRG
[/QUOTE]
I attempted that but found it was impossible with my BAK tonneau cover. The rails require me to "swivel" the divider into place. 2"X10" is the highest I could go. Also I had to go 54 1/8" length. Made the swivelling into position easier. Could also be because of my box liner.
Ford Maverick 54 1/4” divider board for truck bed IMG_2154.JPG
