245 vs 235
Gray Goose
RG
Wissota
I went from a 225/65/17 to a 235/70/17. 0.4 inches wider 1.5 inches taller and that was my results. A loss of 4-5MPG. A 245 would be 0.8 inches wider than stock so even bigger loss. The loss of torque is noticeable too
Big hit to mpg for .75" more ground clearance.
Johnkn
MD
From my post #5 above, I'll get these new wheels/tires on this week and report back on actual weights and results.
The wheels appear to be ~.5 lbs lighter than the stock (2026) XLT wheels while the new 235-65-17 Continental tires are reported to weight ~3lbs more than the stock Continentals.
I spent weeks researching 235/65/17 tires with hopes of balancing (for me only) size vs fuel economy loss, and these Continentals are reported (and do measure) at 8.1+ " tread width wide while reported weight is only 28 (I haven't weighed them yet) .
Nothing in the 235/65/17 size comes close in advertised size/weight .
I have everything in one of my garages and will report back...
For ME, my 3rd Maverick truck is just a daily driver/fishing truck to take the load off my other daily drivers..
More to come.
vanblo21
Logan
Washington
2024 Ford Maverick XLT FX4 4K
More to come.
The extra height definitely makes a difference for looks
Ford Maverick 245 vs 235 20260329_200852
Marty
2026 Ford Maverick Tremor
Went from
225/60R 18’s to
225/60R 18’s
No loss of mileage,
No loss of acceleration,
Pirelli Scorpion AS Plus 3’s
No weight gain, wonderfully quiet,
Smooth ride. Great grip wet or dry.
Due to the superior AWD handling all my roads so well even with the slick thin tread Michelin Primacy’s and after much contemplation on the, ‘Tree of Woe’
I chose this tire to preserve my
Lariats ride comfort and quality.
I’m an old fart.
This pecker head could care less if my truck looks tuff. That’s being cool for real. :XD
Sorry I couldn’t resist that last part.
vanblo21
Logan
Washington
Went from
225/60R 18’s to
225/60R 18’s
No loss of mileage,
I’m an old fart.
I use my pickup in the mountains snowmobiling. The ground clearance and extra traction was needed..not everyone does
Marty
I hear ya,
The worst I’m on is forestry roads, some climbing but if a logging truck can do it loaded I can do it on regular all season road tires. Mostly road bond # 57 gravel.
Reece @ DI
Reece
McAllen Texas
2022 Ford Maverick XLT Hybrid
I just ripped off the stock tires and moved to 235/65/17 Firestone Destination AT/2. These were the lightest AT tires I could find to balance a more aggressive look with MPGs. Since I was keeping the stock XLT rims, I was limited if I wanted to stay under the 30 lbs mark per tire in ATs. If you are changing the rims though, you could easily get some lighter weight rims to offset a larger (heavier tire). I don't think the 245s will work on a hybrid though without some rubbing, but you would have to check to be sure.
rslilly76
rslilly76
rslilly76
Corpus Christi Texas
2025 Maverick XL Hybrid Fwd
245/65 r17 works on all models of Maverick with no rub
Mav4Hogie
Nepean Ontario Canada
2022 Alto Blue/Lariat/LuxPkg/4KTowPkg
Thinking about upgrading my wheels and tires when my OEM tires are done. I am at 15k miles now and have only had the Maverick about a year. I am a 25 Fwd Hybrid. I am actually looking at wheels that are an inch wider than the steelies and thinking about going to a 235/65 r 17 or a 245/65 r 17. Anyone that has done it what has your experience been and what would you recommend? I know either way I am looking at reduced mpg due to the rolling resistance of more rubber on the ground, and the potential weight differences.
I have the stock 18 inch rims and replaced the original 225-60-18. For 245-55-18. As per the pic exact same circumference. But the biggest difference is the actual width of the treads making contact with the ground. Stock tires are about 6.5 inches wide on tread but the 245’s are about 9 inches at tread.
Ford Maverick 245 vs 235 IMG_2647
Ford Maverick 245 vs 235 IMG_2649
Ford Maverick 245 vs 235 IMG_2648
vanblo21
Logan
Washington
The BAP Lariat headlights don’t hurt the look either. Nice!
Yeah Headlights, taillights, painted the grille bar gloss black, Lariat grille. Kinda liked the XLT grille better but I wanted it to look like a Lariat BAP FX4. All thats left is paint the mirrior caps gloss black
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
235 is better in every way except looks.
245 will look better and perform worse.
Not a huge difference between the two to be honest, but since you have a hybrid, I'd personally opt for the 235.
Gordeaux
Gordon
United States
2022 Ford Maverick XTL AWD
I replaced the stock tires on my 2022 XLT AWD with the Firestone Destination AT/2 size 235/65/17 (factory rims). The tires look more aggressive, raised the ground clearance about .65 inches, slightly stick out of the wheel well and I like the raised white lettering.
Overall I have been happy with them.
The ride feels about the same, maybe a little more noise. I saw no significant drop in MPG.
Like someone else pointed out, these were the lightest AT tires I could find to balance looks vs MPG.
BTW the stock wheels lasted only about 40K miles for me, I could have squeezed out some more mileage out of them.
Johnkn
MD
LOL
1) No, installing that size Firestone tires did not result in an additional .65” ground clearance.
B) your stock (metal) wheels only lasted 40k miles? Really?
:facepalm: :facepalm:
