@LarryTheLariatIt says 315MHZ
It's a Lariat Tremor, no start button, with keyless easy entry so... what you say?
My dealership is far and from I've read you need to go to them and show them proof for any keys related info.You need to check what frequency your on before ordering anything
I've had the car for over 2 years now so that sticker is long gone. I'm going to check in the footwell like someone said earlier and see if it has information I need.Don't you have a key fob with a sticker on the back?!
Let us know!My dealership is far and from I've read
I didn't see the MHz and don't really know what the key code looks like. Maybe someone else will check and find it, and they can point me in the right directionThe key code is printed on the sticker on the BCM (near the passenger floor fuse panel) perhaps the frequency is on that sticker as well?).
It was posted the MHz is not on the BCM label. The key code is the five digit number. The key code is the number you enter in when you are programming a new Keypad, or fob if you do not have two key fobs that are already programmed. You can also display the key code on the dash if you have a programmed fob. (I don't remember the steps but their was a thread on how to do it). The MHz's are vin # specific and there was some 22's &/or 23's that got different MHz's TPMS during chip shortages.I didn't see the MHz and don't really know what the key code looks like. Maybe someone else will check and find it, and they can point me in the right direction
If you remove the manual key out of the key fob, probably can see the ford PN as well as FCC IDI didn't see the MHz and don't really know what the key code looks like. Maybe someone else will check and find it, and they can point me in the right direction
Great info! I plug my info in, and I'm seeing 314.95MHz. So the key that I ordered is not the correct one. I'm going to try to find the correct key and see what I can do. Hopefully, what @Quest stayed earlier that the "2x" will work without the module.If you remove the manual key out of the key fob, probably can see the ford PN as well as FCC ID
Plugging in FCC ID into google or https://fccid.io/ can pull up some hits of it and frequency.
*the FCC site seems to be on its last legs, half the time doesn't work.
My Escape's key fob JL1T-15K601-BC, FCC ID M3N-A2C931426 pulls up info that matches its QR code frequency of 902MHz:
It's a 315MHZ for me as well please be kind and let me know if you find the correct key fob!Great info! I plug my info in, and I'm seeing 314.95MHz. So the key that I ordered is not the correct one. I'm going to try to find the correct key and see what I can do. Hopefully, what @Quest stayed earlier that the "2x" will work without the module.
Yea, I found it. Comes in on Sunday lol. It's cheaper than the one from Ali express too. The is link is HERE. If you want to wait until I try it out, I should let you know on SundayIt's a 315MHZ for me as well please be kind and let me know if you find the correct key fob!
PerfectYea, I found it. Comes in on Sunday lol. It's cheaper than the one from Ali express too. The is link is HERE. If you want to wait until I try it out, I should let you know on Sunday
Added the key. The buttons work. The remote start does not and neither does the proximity sensor.PerfectTY let me know on Sunday #funday
Oh oh @Quest is it because the 315MHZ??????Added the key. The buttons work. The remote start does not and neither does the proximity sensor.![]()
Not sure, like I said I I have not tried with older models ,tried on my 2025 & it worked.Oh oh @Quest is it because the 315MHZ??????
@LarryTheLariat what year do you drive?Not sure, like I said I I have not tried with older models ,tried on my 2025 & it worked.
Maybe a key vendor problem or you need to turn on remote start with Forscan
Remote start was already active in my 2025 cluster options , are yours?
The proximity thing seems odd that part should work
2023 Lariat@LarryTheLariat what year do you drive?
