2025 XLT remote start with Cheap replacement key fob
Cancunbadlands
Cancun
Cancun
Larry the lariat
Roli
Miami
Mazda B3000
You need to check what frequency your on before ordering anything
My dealership is far and from I've read you need to go to them and show them proof for any keys related info.
Don't you have a key fob with a sticker on the back?!
I've had the car for over 2 years now so that sticker is long gone. I'm going to check in the footwell like someone said earlier and see if it has information I need.
Cancunbadlands
Cancun
Cancun
Let us know!
Larry the lariat
Roli
Miami
Mazda B3000
The key code is printed on the sticker on the BCM (near the passenger floor fuse panel) perhaps the frequency is on that sticker as well?).
I didn't see the MHz and don't really know what the key code looks like. Maybe someone else will check and find it, and they can point me in the right direction
It was posted the MHz is not on the BCM label. The key code is the five digit number. The key code is the number you enter in when you are programming a new Keypad, or fob if you do not have two key fobs that are already programmed. You can also display the key code on the dash if you have a programmed fob. (I don't remember the steps but their was a thread on how to do it). The MHz's are vin # specific and there was some 22's &/or 23's that got different MHz's TPMS during chip shortages.
BlueSpec1
Gene
If you remove the manual key out of the key fob, probably can see the ford PN as well as FCC ID
Plugging in FCC ID into google or https://fccid.io/ can pull up some hits of it and frequency.
*the FCC site seems to be on its last legs, half the time doesn't work.
Ford Maverick 2025 XLT remote start with Cheap replacement key fob 1755897142353-2
My Escape's key fob JL1T-15K601-BC, FCC ID M3N-A2C931426 pulls up info that matches its QR code frequency of 902MHz:
Ford Maverick 2025 XLT remote start with Cheap replacement key fob 1755896970614-at
Ford Maverick 2025 XLT remote start with Cheap replacement key fob 1755896741130-84
Larry the lariat
Roli
Miami
Mazda B3000
Great info! I plug my info in, and I'm seeing 314.95MHz. So the key that I ordered is not the correct one. I'm going to try to find the correct key and see what I can do. Hopefully, what @Quest stayed earlier that the "2x" will work without the module.
Cancunbadlands
Cancun
Cancun
It's a 315MHZ for me as well please be kind and let me know if you find the correct key fob!
Ford Maverick 2025 XLT remote start with Cheap replacement key fob 20250821_194222
Larry the lariat
Roli
Miami
Mazda B3000
Yea, I found it. Comes in on Sunday lol. It's cheaper than the one from Ali express too. The is link is HERE. If you want to wait until I try it out, I should let you know on Sunday
Cancunbadlands
Cancun
Cancun
Perfect 👌 TY let me know on Sunday #funday
Larry the lariat
Roli
Miami
Mazda B3000
Cancunbadlands
Cancun
Cancun
Quest
Quest
Oh oh @Quest is it because the 315MHZ??????
Not sure, like I said I I have not tried with older models ,tried on my 2025 & it worked.
Maybe a key vendor problem or you need to turn on remote start with Forscan
Remote start was already active in my 2025 cluster options , are yours?
The proximity thing seems odd that part should work
Cancunbadlands
Cancun
Cancun
@LarryTheLariat what year do you drive?
Larry the lariat
Roli
Miami
Mazda B3000
