2025 Must have Forscan Mods?
rslilly76
rslilly76
Corpus Christi Texas
2025 Maverick XL Hybrid Fwd
So I just used Forscan on my son's 22 and what I did was add a few drive modes, add cruise, added LKA, and added TSR
On my 25 hybrid so far I have added TSR, and removed all seatbelt chimes, and actually added lobo mode! LOL
What are your must have 2025 Forscan mods? I would like to know what else I should add or delete and I am kind of new to using Forscan.
I have used Techstream on Toyota a bunch, but this is the first using Forscan.
Ford Maverick 2025 Must have Forscan Mods? PXL_20260213_201536539
Mavster Mechanic
Hybrid
If it's a hybrid you need to set full time headlamps on (not DRL) or full time parking lamps on, or set headlamps switch to "retains previous setting".
(The default returns to "auto". )
You don't want auto.
rslilly76
rslilly76
rslilly76
why not auto? I like auto
and what you mean full time headlamps why do i want this full time
and full time parking lamps why do I want this full time?
Mavster Mechanic
Hybrid
Keeps your 12v battery healthy and long lasting.
Keep it auto and don't drive at night much and your 12v battery dies an early death. Weird, but true in these electrically complex vehicles.
rslilly76
rslilly76
rslilly76
interesting
Frenchy
Bert
Taylorsville Utah
"You don't want auto." WHY?
This thread clearly states 2022-2024, is this even an issue in 2025s? Auto is working just fine for me.
Probably not.
Ask @Mavster Mechanic
I was replying to Frenchy and trying to help him out. I have no idea what year Maverick Frenchy has or whether it applies.🤷‍♂️ That's for him to decide.
Maverick123
Waiting
Does Lobo mode give you errors after using it? IIRC another member here tried it and it would light up the CEL after a while.
I'd love to enable it if it really works ... "formerly called Sand mode" ... also Off-Road mode
rslilly76
rslilly76
rslilly76
haven't seen any yet
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
25 Lariet Hybrid: reporting:
1) Global windows Open & Close from key fob.
2) seat belt chimes/reminders.
3) Eliminate Triple Ding at Startup.
4) Auto lock Initial Value Disable {Doesn't lock doors Every time you exit}.
5) Headlamps Position at Ignition - change to Last Known. FYI, I found Mavester Mechanic's finding about headlights On forcing much better 12V battery charging very interesting. On my 25MY I found zero change, headlights On or Off, monitoring with Car Scanner App, using his parameters. I assume it's a 22-24 MY thing? But Kudos to him for such great work & reporting. I'm betting it helps many of you afflicted with the 12v charging problem.
rslilly76
rslilly76
rslilly76
well most of this doesn't apply cause I'm XL but thanks
however mavster's findings are correct
If you're using car scanner pro you will see that SOC once you hit 92% the actual amps start going negative and discharges battery below 92% everytime
