2025 Must have Forscan Mods?
rslilly76
rslilly76
rslilly76
Corpus Christi Texas
2025 Maverick XL Hybrid Fwd
25 Lariet Hybrid: reporting:
1) Global windows Open & Close from key fob.
2) seat belt chimes/reminders.
3) Eliminate Triple Ding at Startup.
4) Auto lock Initial Value Disable {Doesn't lock doors Every time you exit}.
5) Headlamps Position at Ignition - change to Last Known. FYI, I found Mavester Mechanic's finding about headlights On forcing much better 12V battery charging very interesting. On my 25MY I found zero change, headlights On or Off, monitoring with Car Scanner App, using his parameters. I assume it's a 22-24 MY thing? But Kudos to him for such great work & reporting. I'm betting it helps many of you afflicted with the 12v charging problem.
https://www.mavericktruckclub.com/forum/threads/hybrid-12-volt-battery-crazy-findings.82547/
