I have a developer/beta version of ForScan that has the 2025!
anthonym6
AM
MI
2025 2.0EB AWD
I tried that version on my eco boost. This is what I get.
Install the version I posted. Looks like you’re using the previous beta version.
Ford Maverick I have a developer/beta version of ForScan that has the 2025! 1738962603171-9h
Mini One-Fiddy
Jax, FL
'23 Bronco Wildtrak. '23 Maverick XLT BAP Hybrid
NEW TEST VERSION!
The ForScan people sent me a NEW test version that they claim corrects the errors I was seeing when trying to mess with the seatbelt screens. This is what they said....
Fixed, here is the test build:
https://forscan.org/download/FORScanSetup2.3.65.test20250122.exe
Important: please remove the vehicle profile before the first connect with this version.
Please also note it is recommended to use "Module Configuration" functions instead of As Built, if they are available.
Here is an article about how/why to delete the vehicle profile before using this new version of the software.
https://forscan.org/forum/viewtopic.php?f=5&t=9196
I was able to download this today and eliminate the annoying seatbelt screen. That screen was markedly worse than the one on the ‘23. Thank you for the link!!
twntyfive2life
MN
2025 AWD Hybrid XLT 4K Lux
Was it the same addresses as the 2022-2024 to do this? Going to try it this weekend on my 2025 and I'm assuming it's the same as the 2022-2024 spreadsheet that's posted in the forum here
paneubert
paneubert
Seattle
It is the same on the 2025 as all the prior years. Same coding either by the EZ method (drop-down menus) or by the manual numerical/hex value edits.
SoulSnatcher
Me
Oregon
2010 Ford Escape Hybrid
Contacted the ForScan people and they sent me a developer/beta version of ForScan that has the 2025. If anyone wants me to email them the install file (EXE file), let me know.
I sent you a DM
Please email me the .exe
Thank you
Tbone289
MO
SoulSnatcher
Me
Oregon
You've quoted a post from 6+ months ago. The newest versions available on the FORScan website support the 2025.
But I need the Beta. Can't update modules without the Beta
Tbone289
MO
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
So far I have been able to disable the turn signal outage detection (so I can use my LasFit LED bulbs). Confirmed no hyperflash once I edited those settings. Same method as described in the spreadsheet for the 2022-2024 model years.
But......
I tried to also disable the seatbelt warning screens, but got a checksum error and even when saying "do it anyway", the process fails/ends midway thru. A bit scary. So I did not press the issue. But I am hoping it gets figured out soon in an official ForScan release so I can disable the seatbelt screen. I am wondering if it needs to be in completely different fields, since the coding for 2022-2024 was to just 'Zero out" all the numbers and letters. Seems pretty simple and straightforward. But it seems on the 2025 it isn't as simple as just sticking all zeros into those fields.
My 25MY hybrid - I simply zeroed out the four IPC values & seatbelt warning is gone. I have Forscan paid license if makes any difference?
Tbone289
MO
He has probably worked through the issue since he posted it in January, 2025.
KenE
Ken
Hope so. Just ran across the post decided to respond. ForScan is awesome.
