2025 Maverick Factory Tri Fold leaking
GarryB
Hey all,
My Mav is about 3 weeks new and I noticed a big water leak where the edge of the seal meets the tail gate. Is this normal? It's a Ford factory trifold install. I'm not talking about some dripping, I'm taking about a significant amount of water penetrating into the box.
Anyone else having this problem?
Suggestions?
Thanks
Ford Maverick 2025 Maverick Factory Tri Fold leaking 20250407_145527
Ford Maverick 2025 Maverick Factory Tri Fold leaking 20250407_145559
Hey all,
Suggestions?
Thanks
soft or hard tri-fold? pics would be useful, but I own the Ford soft tri-fold tonneau cover (actually, I'm selling it :D) and never had an issue like this. everything I'm about to say is not applicable to a hard tri-fold.
with the soft, it's very possible to install it incorrectly and have it too far forward, rear, left or right. If you have a combination of too far forward and too far to one side, I could see that causing a major leak as the gaskets don't line up on the tailgate.
it would take you at most 10 minutes to loosen the clamps at the front, ensure it's on straight, and tighten it back down. (edit) one tip I definitely have is that it should NOT be flush against the rear glass. if it is, that's too far forward and you'll have seal problems on both front and rear. there should be a gap between the end of the tonneau cover and the rear glass. this isn't the best pic (because that's not what I was trying to demonstrate) but you can kinda see it here.
Ford Maverick 2025 Maverick Factory Tri Fold leaking soft tri fit
piwtrnr
Union City PA
I have the factory trifold and have driven in a few downpours lately and I have had zero issues with leaks.
ugfbill
bill
TomsRiver, NJ
2025 Maverick Lariat
I have the factory tri fold. The only leaking comes through the car wash. I’ve put down weather strips in the right and left corners. Now it’s minimal.
MarcoG
Los angeles Cal usa
C-Max Energi PHEV, Maverick Lariat Hybrid DEC2023
Agreed. Two years, many downpours and innumerable car washes and details. Some very minor intrusion easily dabbed up with a small cloth. Would l put something in the 4 corners that l would worry about being colorfast, likely no, just because these covers are not "waterproof". However, it's light.
npaladin2000
NY
2022 Maverick XLT Hybrid, 2025 Maverick Lariat Hybrid
Everyone saying "factory tri-fold" there's both a hard and a soft tri-fold.
as I noted, yes.
the Ford hard tri-fold is a bak mx4 and I've never owned one or even inspected one closely in person, but it could be installed incorrectly as well.
Hey all,
Suggestions?
Thanks
Pictures are ALWAYS helpful when trying to describe the situation.
If you own a smartphone you can take a picture and post to the form in less than 2 minutes.
Writing the text takes me longer than posting a picture from my phone.
Hot Runr Guy
West Chicago, IL
as I noted, yes.
I wish they would have made the BakFlip MX4 about 1/2" longer, it's hard to get a good seal on both the front and tailgate. With my Elevate TS rails adding a little height, I added a strip of weatherstripping on the tailgate.
HRG
Ford Maverick 2025 Maverick Factory Tri Fold leaking IMG_1195
Ford Maverick 2025 Maverick Factory Tri Fold leaking IMG_1194
GarryB
GarryB
Sorry it's hard fold. I didn't know you can get soft fri fold
GarryB
GarryB
So should I take it in for a fix? It cost me enough...
