2025 Lariat Remote Start not Heating seats and Steering wheel
boxster03
michael
santa fe NM
2023 Maverick XL Area 51
ahhh yes another MAV software issue - next time buy an Apple that comes with wheels :crackup:
Portcqb
Portcqb
Eric
South Portland, ME
2025 Ford Maverick Lariat Hybrid AWD
In my 2024 eco AWD lariat
In the dash menu/vehicle/remote start settings. I can set to use last dash settings or auto.
I use auto, seats and steering wheel heat up on cold mornings as does the cab. All defrosted and toasty ..
Yah that menu doesn't exists in 25s its in the radio display that I showed above there is less going on in the cluster in the 25 even though it's bigger
Spatty
Jake
Colorado
2025 Maverick Lariat
I have noticed the same thing in mine too in these recent snow storms in Colorado.
RAMS
Rob
NJ
2020 Kia Sorento SX & 2007 Infiniti M35x
Definitely need to check. Only been a few days. But saw your post, when I remote started it this morning if you look under slider toggle in app. You can manually turn on seat warmer and steering wheel from there. Also choose your temp or have it on auto climate.
Portcqb
Portcqb
Eric
South Portland, ME
Hmm maybe that's the issue I'm starting with key fob not the app I'll try the app today
Portcqb
Portcqb
Eric
South Portland, ME
Ok so after doing a remote start in the app and setting it in the app they now start as expected via the key fob. There must be a missing menu or oversight on the initial config for them.
23grayXLT84
Midwest
23 hybrid xlt
Yup, not everyone wants to use the app.
NotARealTruck
Griddle
2015 Scion FRS, 2016 Hyundai Veloster Turbo, 2025 Maverick Hybrid/awd/lariat
Have you tried turning on the heated seats before you turn off the truck?
When I went to go pick up my truck my salesman explained this to me. Turn everything on before you turn the truck off.
Mabcim
Rochester, NY
Just got my ‘25 Lariat.
I too am having the same issue.
I had a ‘22 Lariat, and it worked as expected.
There is a software bug somewhere.
We (myself and the tech guy that goes through features with you) confirmed all the settings were Auto before I left the dealer. I purposely did that because I saw this thread.
I remote started yesterday, temp below 40° F. Nothing was On.
I then reconfirmed the settings were Auto. I also did the ‘change to Off, then back to Auto’ test. Next remote start, they did not come On. Next I started from inside the truck, the seats were On but not the wheel; so I turned On the wheel. Next remote start, nothing was On. So it it definitely not working properly. Adding this to my list of things for dealer to look at; to at least get it documented.
BTW - I find it silly that one is ‘Auto’ and the other is ‘AUTO’. How hard can it be to use the same character casing for settings?
Portcqb
Portcqb
Eric
South Portland, ME
If you look above there is a fix I found remote start with fordpass and set the seat and wheel on in fordpass after it starts. After that point if they were set to auto in the truck they will work when you remote start with the remote.
capecruiser
Bret
southern De
, 1931 Ford , 2025 Maverick Lariat AWD Azure, 2026 Lincoln Corsair reserve ll
My 25 Lariat is doing the same,no heated seats or wheel using the remote start. Also using remote start I dont get a green light on the fob confirming remote start worked like my 23 Lariat had done
Mabcim
Rochester, NY
I did see that post. However, I do not see any seat & wheel options in my FordPass app on my iPhone.
Portcqb
Portcqb
Eric
South Portland, ME
Hmm I'm on Android when you start it via the app a climate section doesn't appear in the iOS version similar to this.
Ford Maverick 2025 Lariat Remote Start not Heating seats and Steering wheel Screenshot_2025-01-19-11-14-44-01_f85a9dcae275ee1e0920d804e6924647
Ford Maverick 2025 Lariat Remote Start not Heating seats and Steering wheel Screenshot_2025-01-19-11-14-49-81_f85a9dcae275ee1e0920d804e6924647
Mabcim
Rochester, NY
I actually have never noticed that. I just move the slide then close the app. They never had that in the older version of the app, when you had to press and hold a button for it to start. I will check. For my last post, I was looking while the car was off.
jeffrol48197
Jeff
2007 Explorer, 2009 Focus, 2019 Explorer
The green light was an eliminated feature on newer Fords...Like the wiper heater, wired keypad and temp display - I just bought my '22, love my truck!
