- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Hanging right on the negative terminal, easy to get to.I have wondered whether the vehicle to vehicle variation in experience is due either the 12v battery sensor part tolerance or even PCM internal A/D conversion of the battery voltage is the cause. Not sure of the lighter outlet or other 12v points are directly across the 12v battery, or rather upstream across the DC-DC converter; i.e. some posts say they see 15v+ at those points. I doubt the 12v battery terminal voltage ever gets that high.
I don't have detailed electrical diagrams for the hybrid to understand where the sensor(s) are, and whether the sensor is cheap to replace, or if it can be "fooled".
Several pics of batteries shows it the same model/part# on the hybrid - been curious if the same on EB, or hybrid Edge or other Fords?
When the power ports read 15V, a multimeter does indeed read that at the battery posts.
I think it is interesting that the circuit to the battery - for use or recharging, seems to be distinct as there are values for it's V and A - and yet the whole 12V system fed those 15V, but not the amp current.
I need to get the amp clamp on it while it's running - see if it agrees with what the BCM is claiming is battery amps for charging.
