2023 XLT...LED Tail light strips?
Jims Maverick
On Line
maverick
Is it possible to install an led rear light strip and not use the trailer hitch connection, to avoid the blis situation?
Cancunbadlands
Cancun
Cancun
*My bad I miss understood*
Blind situation? Where?
People is rear ending car crash because they're texting and driving
No tail light involved
Hot Runr Guy
West Chicago, IL
There have been a LOT of threads on this subject.
HRG
Search feature works well….
commadorebob
Use search to find various options, but yes.
Cancunbadlands
Cancun
Cancun
RickyC
Md
24 Mavrick Hybrid
I tried putting a strip light on my 24 but ran into problems with the wiring harness for the tail gate being right in the middle of where the light strip would mount and there is not enough clearance to mount the strip above of below the wire loom. It did however have a plug in wiring set that allows you to plug into the factory plug and still be able to plug into the trailer lights with out doing any cutting or adapting. Hope this helps.
Jims Maverick
On Line
maverick
Thanks...That's why I am asking here now. I asked a while back and no one seemed to know....just got a lot of guesses and entertainment for people with no clues or hobbies, so they just waste peoples time with nonsense.....
Because of the spare tire issue, a 2 piece unit is needed. The blis issue Ive read work arounds by wiring to the tail lights etc, but no one seems to be very sure of wire colors, connections etc? It seems to me that a wiring unit could be used to block the blis signals, but I havent seen anything along those lines, so I'll keep searching.....
Thanks again...
Jims Maverick
On Line
maverick
Looked at these but no mention of blis compatibility...
Call and ask!! I would think any that are Not connected to the trailer wire connection point would Not affect blis. Naturally, not a best practice to assume anything nowadays so always verify with manufacturer
Maverick123
Waiting
Good suggestion from OleFordGuy ...If you watch the video on the Putco site, the installer plugs it into the taillight harness. If that's the case, it won't interfere with BLIS operation. Also the fact that it lights up white when you're in reverse : there's no reverse signal on a 4 pin trailer connector, so that confirms it's plugged into the taillights, NOT the trailer connector
Jims Maverick
On Line
maverick
I already messaged them..
Waiting on a reply.
lm126027
Larry
Central MA
2024 EB
