2023 Maverick trailer wiring
Drkuhar
Dale
Girard illinois
84 cutlass, 2011 silverado,
Engineering has given my Dealer instructions on how to run a new circuit back to the socket for the trailer running lights. Can't wait to see how this is accomplished,,,,,
HRG
Well if they can run a new circuit then eventually aftermarket will figure out how to run a new circuit and get around this mess that people are having
J R
Rogersville, AL
2021 Nautilus Black Label, 2021 Nautilus Reserve
I have a 2023 Maverick AWD with the tow package. Has anyone had any problems with the 7 pin plug not working correctly? I plug in any of my trailers and only the turn lights and brake lights work. No running tail lights or marker lights. I hook up my F350 and everything works fine. Dealer can’t figure it out.
Yes, spent 3 hrs at Long-Lewis Yesterday. There is no “tail light trailer wire” in the wiring harness. It is a mistake from the wiring harness provider. They put The part on order for my truck.
Should be able to somehow temporarily clip into tail light wire if it becomes important enough to you.
Hot Runr Guy
West Chicago, IL
You too, eh?
HRG
Hot Runr Guy
West Chicago, IL
I'm sorry, you lost me. What mess are you talking about that needs aftermarket attention?
HRG
Drkuhar
Dale
Girard illinois
HRG
Wiring harnesses to add trailer lights and work with a truck and not void the warranty
GPSMan
Many
One has to wonder if they used the same harness for both the 4 pin and 7 pin. Oops!
True or not...
4 pins have running lights.
7 pins have running lights.
Pin 1 ground
Pin 2 running lights
Pin 3 right turn signal
Pin 4 left turn signal
(Pins 3 & 4 simultaneously constitute brake lamps)
The 5th pin is for trailer brakes
The 6th pin is for trailer back up light (white light if equipped).
The 7th pin is for 12v battery charging, if equipped.
Hot Runr Guy
West Chicago, IL
Is yours also a 4K, like @quinngoeck and mine? Trying to figure out if this is isolated to 4K-equipped trucks.
HRG
Hot Runr Guy
West Chicago, IL
Have either of you guys had this resolved yet? Mine's been at the dealer for 2 weeks now, with no end in sight,,,,,,,,
HRG
quinngoeck
Quinn
Utah
2023 Ford Maverick
No I haven’t found a fix for it yet. I’ve been trying to pin the dealer down on it with no luck yet. I’m not taking it in there again until they have a fix for it.
uga
SE USA
2026 Ford Maverick XLT
Could be the reason for the constraint on the stand alone hitch?? (Just a guess)
Automate states: the trailer control module that drives the trailer connector. It has micro-chips and some chips are still in short supply.
This is starting to make sense regarding Hitch constraint.............................................
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
Yes, every Ford vehicle from the factory with a hitch requires a trailer module with micro-chips. And when those chips are in short supply, guess which vehicle gets constrained? The very cheapest one, the Maverick with stand alone hitch.
thevol
GA
Iconic Silver Mav 2.0 AWD 4k
Does the 4 pin have working tail lights? Could jump it right there at back for temp fix.
Hot Runr Guy
West Chicago, IL
Dad
Good grief!
