It's all in the overhang dimensions. It looks like the upper parts of the Tremor's lower fascia stick forwards a little more in the front instead of being flush. And since the package includes a hitch that might be adding the extra 0.6" in back.
kingranchero
Dearborn
www.ford.com
2023 Ford Maverick Tremor
It's interesting that the Tremor is an inch longer.
Is the actual cab an inch longer? It seems so at first glance given there's an extra cubic foot of passenger volume and an extra inch of leg room in the second seat. On second glance, though, it also says the 2.0 model has the extra inch of leg room in the second seat without the Tremor package, so that appear to be more of a 2.0 vs. 2.5 thing than the size of the cab itself.
@Darnon is correct. The extra inch comes from a combination of the Tow Hitch being standard (the hitch protrudes past the rear bumper ~1/2"), and the Tremor's new front lower fascia protruding slightly more forward than the standard '22.
The legroom differences are purely from comparing the Hybrid to the EcoBoost, as the Hybrid has a higher front floor to fit the HV Battery.
All4spl
Longwood, FL
2023 Ford Maverick XLT
Unless there is some hidden changes happening in the infotainment, Sync 3 is ONLY on Lariats. As that is how MY22 was done, XL and XLT got Sync2 or w/e it was called then.
dbmurray
2015 Ford Escape Titanium
Makes sense. Thanks.
Jonny44
Jon
Minnesota
2025 Mav hybrid AWD XLT, 2016 Ford Escape Titanium
It looks like ACC is included with Co-Pilot 360 now. It would be nice to have on the XLT models!
fishinmagician
2022 maverick hybrid XL
Where did you see that? All I see is ACC is listed under "available" not "standard"
Jonny44
Jon
Minnesota
It was not listed with 360 copilot for the 22 models at all. 360 was available for all trims, but cruise was not for the XL. Looks like that's still the case for the XL, hence the "available", I assume. All is speculation, of course, until it's all confirmed!
Bbot
Rob
Escape SEL
I am not sure if others have realized, but it seems that Ford Co has published the 2023 Maverick Tech Specs when published the new Tremor package.
See the Tech Specs at https://media.ford.com/content/dam/fordmedia/North America/US/product/2023/maverick/pdf/2023-Maverick-Tremor-tech-specs.pdf
It was published attached to the Tremor announcement, so it contains tech specs both the Tremor and the other packages.
Based on an initial look, I did not spot any surprises in the 2023 Tech Specs, but maybe others can spot something interesting.
EDIT: I have also added the 2022 Specs for comparison.
Payload dropped to 1200 lbs in the Tremor package, considerable increase in vehicle weight. For those that were going to do these changes anyway considering the realities small increase in price and because of installation by Ford, it would be covered by the 3 year warranty … just makes sense If They Can Deliver a Finished Product !
Maverickman74
Shane
Maui HI
I would like to note that the weight increase doesnt match the payload decrease. To me that says more offroad suspension capability, should be nicer ride than the Fx4 in the rough stuff.
fordluvr44
Yes
This is absolutely massive if true. Like HUGE.
I wouldn't buy a Lariat if I could get ACC on the XLT
Maverickman74
Shane
Maui HI
ACC CP360 a Jedi has no need for such things.
HTX
Jon
Houston TX
CR-V
Not seeing this but would be a big deal if true. Come on Sept 15!
XLTLUXA51
Ezra
Hardwick Vermont
Ninja 650r, Suzuki SX4, Buell blast 500
I think you always could get it on the XLT just not on the XL
PA-Homesteader
PA
N/A
Why can't Ford just add Cruise Control to the XL?
I guess I will be doing it myself 🙄
fourjays30
Nissan Frontier
Would have liked to see XM radio as a option on the xlt
