2019 Ranger 2.3T turbocharger specifications
Dueces
Hello everyone, this is my first thread I've made here, but I've randomly been in some of the more performance oriented chats.
I am still waiting for my Maverick to be delivered, it's been sitting in Chicago for 3 weeks now, not sure what they are holding it for.
While waiting, I have been doing some research, and I have been looking at all of the turbos on the 2.3T models in Ford's lineup. I ended up with this turbo because it was cheap, and I found dyno videos showing 93 octane tunes putting down roughly 310-330whp in rangers and explorers. Even more with an upgraded high pressure fuel pump, and E85. That dyno was 355whp/474wtq. So, I know this turbo is more than up to the task to making the power I want out of the Maverick.
So I took a bunch of measurements of the turbo and will show that all in my pictures. The compressor wheel is a 46mm inducer/61mm exducer. I haven't found actual specs of the Maverick's turbo, but judging by the few pics I have seen, I'm guessing the compressor inducer is between 42-44mm.
There are a couple issues I haven't been able to verify yet. On the Ranger/Explorer turbos, the electronic wastegate actuator is actually a mirror image of the Maverick/Escape/BS unit, and as long as the connector pinout is the same, I think this will not be a problem, but I need to verify that. The other issue is I am not positive yet if the exhaust bolt pattern is the same between the units, I'm thinking they should be, but again, I need verification.
The only other major change I think the Maverick is in need of, is the intercooler, as has been posted by many. Thankfully, someone on here has already fitted a Focus RS unit on their Maverick, an I plan to do the same.
Ok, sorry for the long read, on to some pics!
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_210228
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_174349
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_174355
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_174409
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_174422
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_175408
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_204117
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_204225
Ford Maverick 2019 Ranger 2.3T turbocharger specifications 20220429_204336
Thanks for looking, if you have questions, or need specific pics, let me know!
If noone gets detailed info out about the Maverick turbo, I will do so when I get my truck!
stangg17
Chicago
The biggest problem with tuning these is that the transmission is undersized by a reasonable amount. Software is the only think keeping it from being shredded to pieces.
Scott Asheville
Scott
Asheville, NC
I think you should have a blast (hopefully not literally) modifying your Maverick! Can't wait to see the results.
Dueces
Dueces
Do you have proof of this? I haven't heard of anyone breaking a trans yet.
What generally kills trans is an overabundance of torque. With a larger turbo like this one, ironically enough, the dyno's I have seen show less peak torque than the Maverick dyno's I have seen. I'm not a fan of rushing peak torque as fast as the engine will make it, because that makes a very peaky torque curve. My plan is to work with a tuner to bring torque in slower so it doesn't see 373wtq way down low in the powerband, like the maverick has shown to do. A larger turbo will only help in this as well because it will be more lazy.
I'm 100% with you on the trans being the physically weakest part of the setup, but there are ways to help prolong it's life, and have a great powerband up top! I would love to get some actual trans part numbers off of the Maverick, so I can do more research, but I haven't seen any posted yet.
Maverickman74
Shane
Maui HI
Love to see power upgrades, hopefully someone will come up with a transmission upgrade. I honestly cant believe I am buying a new vehicle with a automatic trans. First I wasnt ever going to buy a new vehicle then the Bronco had me interested with its 7speed. Now the low cost of the Maverick and its capabilities has me hooked, line and sinker. But damn I dont want another automatic in my life. I have only had 40% of the automatics I've owned not give me troubles within a couple years of ownership.
Please someone dig into these slush boxes and find us a complete upgrade for em. That way I can push the Mavericks 2.0 to where my old 306 Mavericks 400 tire shredding hp was(even that Mav had a broken parking pawl on its TCI superstreet fighter C4).
jewc75
The trans is a 8f35 and has been around since 2017. The 2.0 already produces more torque than the trans is rated for.
cannon
mark
oregon
2022 Maverick XL awd
Part # NZ6Z7000B in my 2.0 without tow package, NZ6Z7000D with it.
Dueces
Dueces
Awesome, thanks!
tmoney20g
tony
hammonton, nj
2022 Maverick XLT FX4/Lux/4k/CP360
Dave @Buschur also sent out a factory turbo to see what someone could do with it, don't quite remember where he sent it to....
Dueces
Dueces
Yes I know what Dave has done. That's why I'm looking at these turbos, because I'm not paying $1000+ for a turbo upgrade, and $900 for an intercooler. I plan to have less than $1k into the performance mods of my Mav. Unless I get into the transmission side of things, then I know it'll get expensive....
stangg17
Chicago
I'm getting this info off several forums. Pretty sure someone bere also posted about that. And looks like some responses in this thread echo the same. I'll link if i come across it again.
Dueces
Dueces
I have heard the same thing echoed around the forums, but I haven't yet heard of a single failure. I get that this isn't the 8F57 from the Edge ST, but I have been searching all over the place to find info, and all I keep seeing is the 8f35 being mentioned. Even when looking at the 2020+ Lincoln Corsair, if you look up axles, even the 2.3T for that shows the trans as an 8F35, and that 2.3 puts out 295hp/310tq!
I do not have factory manuals or any way to get ahold of factory info, maybe someone that works for Ford's parts department can be of some help? I hear the term 8F45 used as well, but have never seen anything relating it to a vehicle....
I'm still spending tons of time researching, so hopefully there are articles that can clear some of this up.
LC48
Johnson County Texas
I have not been able to find any actual Ford data on the 8F35 torque limit / rating. The only info has been a couple of old trade magazines that claim the Fords target torque for that box was lower than what 2.0 produces.
The only other piece of info related are @Buschur findings on the dyno with the factory tume closing down the throttle to apparently manage torque. Why they are doing that is up for debate.
Dueces
Dueces
Every new vehicle, especially turbo, runs torque management to keep components happy. They damn sure aren't in it for guys like me that want more power, they need components to last as long as possible to avoid warranty work, keep them in the black.
