0 to 60 Maverick times
300deteh
Darrel
NC
Hey guys. I have seen videos of mavericks getting some pretty good 0 to 60 times. Low to mid 6's. Mine is hovering in the mid to high 7 range. It has the Turbo, lower gear ratio and sport mode. Any ideas, tips or suggestions? Thanks folks!
Deerslayer1980
Michael
Kansas
2022 Ford Maverick AWD
What size tire? Are you using a dragy? Using the speedo and a stop watch aren't accurate. I run 6.1 to 6.5 depending on temp with 235/65/17 Falken Wildpeaks. Ran a 6.1 in cool temps of 52 or so. Heat soak will hurt 0-60s. Ran a 6.6 in 90+.
Jah.
Jah.
Central Florida
I have had identical motorcycles in every way except color . one had better grunt at low end and the other had a higher top end speed . both were good bikes .
300deteh
300deteh
Darrel
NC
I have the stock continental tires. 225/65/17. I did add a k and n filter. And it is in the 90's here. No dragy. Trying to just use a stop watch. Thanks!
Deerslayer1980
Michael
Kansas
You're probably quicker than you think. I'd say mid to high 6s in those temps.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
do you have max tow package (3.83 gear ratio)? run premium fuel?
Nighowl2000
Roy
Ottawa
I have the tow package but my times were with 87
Use 91 octane.
If you use 87 , the computer will limit the horse power down to prevent engine knocking.
300deteh
300deteh
Darrel
NC
Use 91 octane.
Oh, ok! Thanks for the tip! I will report back soon!
Jah.
Jah.
Central Florida
Geez ! My runs like a scalded cat when l gas ( 87 regular) it and turbo kicks in . mpg suffers when you kick in turbo . l do drive speed limit 99% of time . averaging 23 .5 mpg city driving .
300deteh
300deteh
Darrel
NC
Geez ! My runs like a scalded cat when l gas it and turbo kicks in . mpg suffers when you kick in turbo . l do drive speed limit 99% of time . averaging 23 .5 mpg .
I am getting 31 mpg's with it on 87. All highway miles, though.
rlhdweman
Random Lake Wisconsin
Are you lucky enough to live in a state that sells 87 without ethanol?
Deerslayer1980
Michael
Kansas
