- First Name
- Gary
- Nov 9, 2025
- Grand Canyon, AZ
- 2025 Maverick XL Hybrid AWD 4K Tow Package
- Engine
- 2.5L Hybrid
The hybrid does a lot better with varying speeds and lack of NEED to run the Atkinson... i.e. if you aren't using AC or heater when it's cold.
Rolling hills are great - power up, recharge down.
About the only time I've seen the engine vs motor equation result to be very engine heavy is with sustained high speed interstate travel with a set speed cruise control.
As was noted, electric only is limited in range to a mile or so without any regeneration putting power back into the drive battery.
The way you drive the hybrid makes a huge difference. After using the hybrid coach, I'm hitting 100% recovery 95% of the time. It makes a big difference over the course of a tank.
