XL bed cubby install -- step by step DIY writeup with pics
cvano003
Colin
Miami
2024 Maverick XL Hybrid
how do you remove the bed tie downs? I tried a Torx 30 and it feels loose, I dont want to strip the screws.
Lake Michigan
Ford Maverick XLT Hybrid
Is there a non-dealer source for W505424-S450B bolt either locally or online that is reasonable cost?
Fdnewbie
New Hampshire
18 Honda Civic LX 6M
Yes. Remove one of the 4 bolts from your current cover plate. Take it and match it at the store. I found some bolts with the big washers on them at Autozone in the trim clips and bolts section. They were black oxide like the OEM bolts, not rust proof, but good enough with a tonneau cover. The match was pretty close, the thread size and length should match, the hex head size can be a little smaller or bigger, no worries. You re-use the four on the current cover and only need 2 more for the cubby. Sorry I have no part numbers or receipts. The bolt size and length is in one of the replies above.
