Driver's side bed cubby with AC outlet on the inside
KathyG
Kathy
Northern CA
2023 Maverick Hybrid XLT
the trick was to drill corner holes in the cubby using the template, then using a metal ruler lined up on the holes I cut into the plastic and just kept cutting and cutting into the grove till I cut all the way through.. the hole for the light switch was cut the same way except I didn't need to drill any corner holes..
another quicker method is to use a soldering iron tip to melt cut the plastic, but that can end up messier.. I went with the more patient elbow grease and box cutter method..
Or use a multi-tool - cut plastic really easily - just go slow and follow your lines as he says!
midnight43026
Hilliard, OH
2025 Ford Maverick Lariat 2.5 4k AWD
Thanks yds for leading the way on this project — I was planning to do the same and you saved me some time!
I designed a 3D-printed mount that recesses the bed light switch, helping protect it from damage during loading and unloading.
I find the switch relocation to be much easier to use. Feels better than factory!
Link to the 3d print file:
https://www.printables.com/model/1441292-ford-maverick-recessed-bed-light-switch-mount
Ford Maverick Driver's side bed cubby with AC outlet on the inside IMG_20251010_222742194_HDR
Ford Maverick Driver's side bed cubby with AC outlet on the inside IMG_20251011_090407027_HDR
Ford Maverick Driver's side bed cubby with AC outlet on the inside IMG_20251010_222726145_HDR
Don806
Don
SE Ohio
thank you for the 3d print file, I had a coworker print some of these for me, gonna try them out this evening.
midnight43026
Hilliard, OH
This print fit perfect for me, but all printers and materials are a bit different. Quick tip: If you need to make any adjustments, I use a torch and razor knife. Heat the knife with the torch and use it to melt/move the plastic a little bit as needed.
Don806
Don
SE Ohio
Perfect fit for me
I like its recessed where my cutting into the blank wasnt, more of a factory look
Ford Maverick Driver's side bed cubby with AC outlet on the inside IMG_2740
Ford Maverick Driver's side bed cubby with AC outlet on the inside IMG_8724
Ford Maverick Driver's side bed cubby with AC outlet on the inside IMG_1428
midnight43026
Hilliard, OH
Perfect fit for me
Wow, that looks good. I think your latch is tight like mine was. I should loosen it up in the print for future people.
Great looking lights!
