Driver's side bed cubby with AC outlet on the inside
Don806
Don
SE Ohio
Looks good.
Can someone post a picture of what all this looks like from the Factory?
Not sure I can get a pic outside in the dark at the moment. This is his pic of the original panel with the outlet, light, and switch removed.
Ford Maverick Driver's side bed cubby with AC outlet on the inside 0E318EE4-EB93-41E4-B24E-00FFF91E0020
yds
yds
NJ
Carbonized Gray Maverick
Can you elaborate on the wiring from the OEM bed light to the bed rail lights?
https://www.ebay.com/itm/185439327445
I ordered a this ☝ pigtail and soldered a DC5525 barrel connector to it and plugged that into the plug where the OEM led light used to be. the DC5525 barrel connector then plugs into the after-market LED controller box.. I bought a 10 pack of those DC5525 barrel connectors for a couple of $$ -- they were thin af -- maybe that's why the LEDs are kinda dim? 🤔 it's easy to fix tho, I just need to find a better quality DC5525 barrel connector.. either way that pigtail from eBay is the way to go if you want it to be plug and play to the OEM LED connector..
Don806
Don
SE Ohio
Did you reinstall the bed light with the other LEDs?
yds
yds
NJ
no, the og LED bed light is out of the picture.. I just reused the connector.. if you wanna retain the og bed light you'd need to hack together a passthrough with a splitter between the og harness plug and the OEM led bed light, then add a barrel connector or whatever you need to the splitter for your after-market LED lights..
Deleted member 9167
Guest
Oh I see. So the flexbed connector is the same as the OEM light?
Don806
Don
SE Ohio
I ordered a different 12v light for the other side, was hoping to be able to reinstall the oem bed light if possible after the cubby install. Gonna see if one is available to purchase from the parts dept if it’s reasonably priced. If not, will get another of the ones I have coming from amazon
Efab
Edwin
Nevada
Ford Maverick XLT FWD 2.0 EB LUX
inspired by this video, I ordered a Ford NZ6Z-60286A72-A Compartment along with a pair of extra bolts W505424-S450B.
since my Lariat Lux came with the factory 120V AC outlet and LED light, I transplanted the AC outlet to inside the cubby and moved the bed lighting on/off switch to the DIY wiring cover.
not shown, I ordered a DIY wiring pigtail from eBay -- this same pigtail also fits the plug for the factory LED from that bed panel. this allowed me to get rid of the factory LED and reuse that plug for LED strips I mounted on both sides of the bed. that on/off switch now controls the third-brake-light bed lights as well as the aftermarket LED strips.
I used painter's tape on the og panel to cut a template in the tape for the opening to cut in the cubby. I then transferred the painters tape template to the back of the cubby, drilled a hole in each of the corners, and cut the opening out with a boxcutter using the drilled corner holes and a metal ruler to keep things lined up. I then inserted the outlet from the back and used the outlet itself as a template to drill the holes for the bolts.
this last image shows the plug above the muffler which connects to the factory AC outlet. to reach the back of the cubby, the wires going straight up needed to be unclipped from the hole in the metal there. I used a plastic crowbar shaped tool to rip that clip out without scratching up the paint.
idk where you live but ill be willing to pay you for your time in doing this to my truck if you ever come to vegas 😂. Good job!
  • Like
Reactions: yds
yds
yds
NJ
yah.. there might be some plastic tab that's slightly different, but the plugs fit and the lights work and that's good 'nuff for gov'ment work..
yds
yds
NJ
thx.. I'm on the bEast coast in Dirtee Jerzee.. I'll ping you if I'm ever out in Vegas.. the mod is really not that hard to do if you don't rush any of it.. I'm real happy with the mod now that I've lived with it for a while.. truth be told I have never used the AC inverter outlet, I probably never will.. but nice to have it tucked away in there nevertheless.. I do use the cubby all the time, so the mod was definitely worth it for me..
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
Did the cubby come with a bottom panel similar to the passenger side that keeps wheel crap from penetrating the taillight area?
If not, how well does the cubby function for blocking crap from the wheel getting on the taillight?
Thanks
yds
yds
NJ
the cubby was just the cubby you see in the op pics -- just the plastic box with the interior divider and cover..
I haven't looked to see how gunked up the taillight might be after some driving, but the cubby box does sit right in the way between the rear wheel and the taillight, so I imagine more road gunk ends up on the underside of the cubby than the taillight.. that might be a very small win, but I'll take it..
I believe they skipped out on that plastic bottom panel cuz the heat from the muffler would melt the plastic.. someone made a post or a vid about making a similar in functiion driver side panel out of sheet metal so it can take the heat from the muffler..
Aherpa
Iowa
I looked into this mod as a way to get the taillight better protection (seriously Ford, how long have you been making vehicles anyway). Now that I see it in action, I think I'll do it.
What is the gizmo above the light switch? Is it part of the vertical cargo netting?
Ford Maverick Driver's side bed cubby with AC outlet on the inside 1670907005460
yds
yds
NJ
Ford Maverick Driver's side bed cubby with AC outlet on the inside dXdpma
that gizmo is where the bed extender gets anchored.. the three holes are already pre-drilled to match common generic bed extenders you can buy on Amazon like what I got there..
Don806
Don
SE Ohio
Hoping this helps with stuff getting thru and covering the tail light area also. Couldn’t believe how much dirt and water spots were getting up in there 😳
