Why not larger gas tanks?
bearsfan647
Detroit
EBike - Future Ford Maverick!
If Ford's goal is to simply manufacturing then why not just use the larger gas tank for both Hybrid and Eco's?
the goal isnt to simplify for the sake of it.
if they arent having issues sourcing tanks, why change it?
GPSMan
Many
Hybrid tank size is approximately this:
Ford Maverick Why not larger gas tanks? 1DF8377F-2AB9-4FED-AE94-244E12D3C0ED
Of that; the computer marks an imaginary line for MTE 0 after you burned 13.8.
wax87
wax87
Stuart
Dallas South
2004 Avalon
Listening to Tim Bartz, he was talking about the sliding glass back window being eliminated, and made it sound like it was more for standardization which = lower production turn time than it was a supplier issue, I was just thinking along those same lines. However I guess the gas tank for the Atkinson motor is different may be pressurized or something. I am still looking for an explanation on the fuel system for it.
wax87
wax87
Stuart
Dallas South
2004 Avalon
GPSMan
Many
MTE = what? Miles To Empty?
Right.
13.8 is the conservative value, if relied upon, should never run you out of gas. That said, we can use all 13.8 gallons. You don't have to mentally keep an emergency reserve. It's built in.
rlhdweman
Random Lake Wisconsin
Isn't 500 miles of range enough? I can hardly drive 100 miles without having to stop to pee.
Yes, the fuel system on the hybrid is pressurized to help keep the fuel below its vapor pressure so more stays liquid to be used directly. This is why the hybrid has a solenoid locked fuel door.
The hybrid in part exists to help meet low-/zero-emission targets so less emissions and higher fuel efficiency are the goal even if it means a bit more complexity. See also Ford working to get the hybrid's emission certification upgraded from ULEV50 to SULEV30 around Job 2 '22MY.
Bobinmi
Mr me.
SE Michigan
walking and talking
36k on my 2022 maverick hybrid and haven't had an issue with the tank size.
wax87
wax87
Stuart
Dallas South
2004 Avalon
To be honest, I had to go look up what you were talking about.
Montana
Cost for consumers. The whole point is to not have to pay $100 to fill up at the pump.
Yes the hybrid is pressurized and instructions say to not top off to prevent possible hazards (does not say if hazard is to person or vehicle). A button is pushed to depressurize the tank and unlatch the fuel door and if that doesn't open doors then there is a manual cable to pull to Do it.
