When will the "re-designed" CV axles be in?
NebraskaMan
The dealer verified I did indeed have the CV axle issue a month ago. He said Ford had put a nationwide stop on the part as its undergoing a re-design. I have no idea if any of this is accurate but this is what I was told. I was told to take your Maverick home and we'll call when we have the parts and ready to do the repair. No advisement on whether to keep driving it or not.
I keep reading people are having theirs fixed currently, some are waiting like me, some are on their 2nd and 3rd replacements already.
When I first heard of this issue they said it was a Hybrid issue only, obviously not true. Then I hear its ECO's too, but not Tremors...also not true. Very disappointing issue.
Are you guys with issues who are waiting for repairs continuing to drive? Any more clarity on time frame for the "re-designed" part?
AF Blue
US
NA
Looks like you are up to date on info.
Small sample from MTC ... mostly hybrids .. some Ecos.
Some modified lifted/lowered. A good number all stock. Still CV failures happening.
At least one Tremor, lifted, amongst the gang.
My '23 is stock with aftermarket wheels/tires 245/45/20 so .2" taller and just wider than stock.
Some reasons/thought on why they fail:
- Mods Lifting/lowering
- Torque ( ..esp. hybrids with regen)
- Just cheap/weak CV from the OEM.
Nothing is for sure ... just stuff i read on the interwebs.
Vaportrail
Arizona
XL
I believe it's just a weak part-
CV axles are very common these days, and you don't hear about other makes/models needing CV axles replaced so soon. They commonly last well over 100k miles...
Ozarkbeard
They have been re-designed and should be available. There have even been photos of them on MTC, by members who've had them replaced.
You can continue to drive it.
Do a Title search on the forum for CV axles or half shafts.
Snox801
Levi
Spring Lake Michigan
I’m running 265 tires much bigger and wider. Been tuned for 50k.
Lots of launches and abuse off road. Hell was somewhat stuck twice today pushing g snow with the front bumper requiring rocking it back and forth.
Who knows what cause the failure. But glad they are getting an updated part out .
sanhozay
gary
Central California
22 Maverick XLT LUX 4K
I have lowering springs, and the mechanic detected it was from within the CV axle, which they mentioned they have seen on unmodified ones as well.
carcrasher89
Maryland
24 maverick
What issue is this that I need to look out for?
Fagetaboutit and drive your truck.
It will let you know If and when it needs attention.
We got guys with over 100,000 miles and they never had problems so far or we’d hear about it.
carcrasher89
Maryland
24 maverick
Yes that is reasonable but maintenance is something I keep an eye on. And starting today I use my truck for work.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Torque does not cause CV axles to fail.
Bottom line - it was a cheap design and too short where there splines were backing out of the collar, stripping, and ruining the axle.
Vaportrail
Arizona
XL
You will detect a slight wiggle/shimmy/shake in the steering wheel when accelerating. I first detected it at just under 50k miles when accelerating from 50 mph.
It took me nearly a month to get it repaired. The shake kept getting worse, but was still drivable when I finally got it repaired. My front tires wore prematurely wore out from the shaking. Another member had to replace a control arm assembly, since the bushing that wore out from shaking front end, can't be replaced.
carcrasher89
Maryland
24 maverick
Thank you for that information how much did it cost and or was it covered underneath manufacturer warranty and did they replace your tires and if so, how much?
AF Blue
US
NA
I really hope this is the real issue and the new part numbers fix it.
For me, either way, I am committed to keeping my Mav until the axles fail .... oh wait ...!
Is that why they say "drive it until the wheels fall off" ??
Vaportrail
Arizona
XL
Axles are covered under the 5Y/60k power train warranty.
The dealership alerted me of the worn tires, and offered to sell me a new over priced pair.
Vaportrail
Arizona
XL
I was planning on selling mine, then buy a 24 xl.
But I'm having so much fun driving it now, on coilovers, I just might keep it...
Changing CV axles are a pain, but not a deal breaker for me.
If I can get reasonably priced parts, I'll replace 'em myself if they wear out again...
