What's done to tow?
sunismymed
NY
22 xl
Besides setting the Drive Mode Control to "Tow/Haul" is there anything needed to get the 4 pin trailer lights to work?
GPSMan
Many
You don't even have to do that.
You can tow in any mode.
BradnChristine
Brad
Wyoming
Ford did some weird trailer wiring recently, and this may be your issue. My Maverick isn't here yet, but I have a 2020 Transit that I tow with. I tried to do a continuity check for the various pins, but got strange readings.
I finally found out that in order to get the hitch electrical connector to work, I needed to 1. turn the ignition on and 2. actually connect the trailer in order to have power in the connector. Without the trailer connected, I got odd readings and some pins seemed to be unconnected. You might just try one of the 4-pin testers with lights...but if all else fails, you may need to do what I did and actually connect a trailer lighting system to see if that does it.
GPSMan
Many
I figured the OP was alluding to something like using the trailer lights for something other than a trailer.
Foiled!
But that's not what the OP asked.
sunismymed
sunismymed
NY
22 xl
For an EB with 4K tow package - Attached a 4-pin trailer: no lights.
Johnkn
MD
Do the trailer lights work when plugged into another tow vehicle?
GPSMan
Many
Sounds like a problem.
My trailer lights come on when I use the keyfob to lock and unlock the doors. I don't even need the truck running, any key in the ignition, or any "mode" at all.
You may have a bad fuse or loose wire.
Johnkn
MD
That’s because Mavericks like many modern Tow vehicles have a powered converter built into the circuit to sense the presence of a trailer being plugged in. The trailer needs to be plugged in in order for the correct voltages to be present..
Do you have the factory 4 pin hitch installed? If so plug in the trailer and hook it up to ball then turn the maverick on (be sure the trailer is properly wired to it's 4 pin connector). If your turn signals on the dash hyper flash your trailer may not be wired properly or some bulbs are out. I have not hooked up my trailer yet so have not tried this yet. Someone reported that the trailer lights are controlled by computer. I have not confirmed this yet. You should not necessarily have to have truck in tow/haul but maybe it has to be that way if it's computer controlled. 🤷. You possibly may have to have the trailer wire harness checked by dealer. Does trailer work on different vehicle?
Check to see the 4 pin ground wire (white) is grounded to the trailer somewhere properly. After it feeds through the 4pin plugs!
GPSMan
Many
FYI- Once "detected" there is a menu on the instrument cluster that automatically tests your trailer lights and tells (me) "all trailer lamps OK".
So ya, it's looking for specific amounts of resistance or current draw. My trailer is 20+ years old and has all incandescents. I wonder if really low wattage LED are going to give people trouble.
Still I think there is a wire defect in the OP.
sunismymed
sunismymed
NY
22 xl
Looks like my first issue with the new truck, which otherwise has been great. Not sure who to approach.
The Weatherman
Dean
KY
As a last resort you can use a 7 to 4 pin converter pigtail. They are a little harder to find but works.
Ford Maverick What's done to tow? 1670935302538
Mabcim
Rochester, NY
I used the 4pin on my Eco 4K with no issues at all.
dalola
Retired
SE Ohio 🇺🇸
Your dealer....this is covered under your 3/36K warranty.
