Warning!! Check all nuts when doing oil change (for oil leaks)
Brian214
Hyundai Elantra GT, Ford F550
Warning!! If you do your own oil changes I would advise you to check all these nuts, I noticed a little bit of oil leaking when changing my Eco Boosts oil, Every nut I could get to was loose, Driverside of the front of the engine, Looks to be a timing cover.
Edit: It has been pointed out that this is the Transmission pan
Ford Maverick Warning!! Check all nuts when doing oil change (for oil leaks) IMG_8229
Brian214
Brian214
Jamsandolina
Samuel
2024 Ford Maverick XL
What year and how many miles on your maverick?
84IM
2022 Maverick, 2016 Honda Fit
Thanks for the heads-up. I'm planning on doing an oil change next week, so it will be a good time to check all the bolts.
Also, I'll look at the axle boots for any seepage.
At 9500 miles I don't expect to find an seepage, but one never knows.....
Snox801
Levi
Spring Lake Michigan
Looks more like the pcv cover than the timing cover but may be the angle. Either way if it leaks better check it.
TwoTone
MD
Outback 3.6
Just more reinforcement that lazy Oil changes are worth the tiny time savings.
Brian214
Brian214
It has been pointed out to be the transmission pan
trumpet77
2023 Maverick XLT, 2009 Porsche Cayman
One Google search says the 2.0 Ecoboost in Maverick is made in Cleveland and Spain.
paneubert
Seattle
Shhhhh.....they wanted you to say "Mexico" so they could dog whistle some racism without literally saying it.
Mavtremor24
Tony
Ohio
2024 maverick tremor 2024 space ford explorer timberline 2000 black svt contour
Wait till they find out the truck is assembled in Mexico...smh
