Using Maverick to move / tow a loaded roll off dumpster?
RRaynor2
2022 Maverick Lariat
I've got a problem. A contractor has left a roll off dumpster in front of my garage, and the company is having "trouble" picking it up. It's blocking the door from opening (they dropped it too close when I wasn't home).
My question for everyone is, could/should I use my Mav with 4k tow to try and move it forward one foot so I can open the garage door? I think the entire thing probably weighs around 10k. Would I be crazy to try to nudge it a foot by "towing" it?
I assume the 4k rating is for long, controlled, safe tows. But what can the truck do over a foot?
paneubert
Seattle
If you have a kinetic tow rope, I say "send it".
jewc75
It probably doesn't weigh anywhere near 10k unless its full of rocks/bricks. Hook a strap to it and move it, just realize it could mess up the driveway where the skids are.
GPSMan
Many
You'll be surprised what you can move with a pry bar also.
1 man can move a train car (200,000lbs) with a 6 foot pry bar. (I've done it.)
GeoJoe
George
TN
F150, Odyssey, Vibe
Rent a come along if you got a tree to attach it to.
Ford Maverick Using Maverick to move / tow a loaded roll off dumpster? Screenshot_20230922_142154_Chrom
tired comet
markus
ORD
Mav XLT hybrid
I'm more than happy to overdo it but I don't think I would take the chance of ruining my trans or linkage trying to move a dumpster. Not worth the risk for me.
However, you haven't stated how big of a dumpster. A little 5 or 10 yarder I would probably do. A 30 yarder probably not.
TheWizziard
Texas-RGV
Try to move it. What do you have to loose.
Nothing I can think of as long as you use common sense.
You would be surprised of what work I was able to safely do with a past Samurai and a past Ranger.
swtiming8
Wayne
Mishawaka, Indiana
Focus
I wouldn’t even if it could. It’s their problem. I’m sure they wouldn’t will not be liable if it damages your Maverick
RRaynor2
RRaynor2
It's a 10 yarder filled about half full with dirt. Spec's on a 10 yard are 3500lb empty, and cubic dirt can come in like 1500lb a yard. I think 10k is a reasonale guess. It's on rollers so i might try it. They at least put ply wood under the rollers to protect driveway.
GPSMan
Many
Rent
Use a pry bar.
I've done this. Remarkably easy.
Ford Maverick Using Maverick to move / tow a loaded roll off dumpster? D48D5199-8971-466F-8FB1-D850DB8F3075
Maverickman74
Shane
Maui HI
I would attempt. But I would know by the time I got the rpm over about 1400 rpm if it was happening without issue or not. If it can't do it just above idle. It shouldn't do it.
RRaynor2
RRaynor2
Rent
Use a pry bar.
I like this idea as a first attempt, although I suspect the axle and bearings of that car have much less friction than the rusty roll off "wheels". I'd love to see the rolling resistance comparison, haha.
Maybe I get some block and tackle and test Archimedes' theory.
Tim d
Alpena
Ram
It would probably move it,but personally I wouldn't risk it.
RRaynor2
RRaynor2
*UPDATE*
I tried the prybar method, didn't come close to budging.
Out came the tow strap and I dropped it into low with tow mode on. I was gentle on the gas and kept it under 2k rpm. After 3 tries, immediately gave up as the dumpster didn't even wiggle.
By some miracle the truck showed up late Saturday, just in the nick of time.
I asked the driver about weight, and he confirmed a fully loaded 10 yard rolloff, with dirt, is 30k lbs! He said scale verified. Half loaded he guessed 20k.
In summary, the Maverick with 4k tow will fail to move a 20k lb roll off.
Ford Maverick Using Maverick to move / tow a loaded roll off dumpster? 1000027225
GPSMan
Many
Ya. A yard is a ton in most cases. When you said 1500 I wondered if you had a lot of low density stuff. Wet dirt, more than a ton per yard.
At my work we use those.
Delivery truck can deliver two empties at once, but can only haul away one full.
With the pry bar I guess it depends what you are pushing against.
