Underhood jump points don't work ...
Deweyordeweynot
Dewey
Macomb, MI
I had to jump the 12v battery last week and couldn't do it via the power points under the hood, so I went to the battery posts and got the truck started, and it got me thinking: do my power points actually function? My battery tender showed no connection but it needs a minimum amount of charge detected in the battery to work, so I decided to put a multimeter on the power points (after fully charging the battery), and there's zero voltage on the meter. The Ford dealer will be looking into it today but I wanted to suggest you check your underhood power points, just in case...and I purchased a NORCO GB40 Boost+ jump box and it shows no connection when attached to the jump points. Good thing I discovered this in the driveway!
Deweyordeweynot
Deweyordeweynot
Dewey
Macomb, MI
Here you go...
Deweyordeweynot
Deweyordeweynot
Dewey
Macomb, MI
EffNo50
Central California
REMUB40
Fredericksburg, VA
2018 Honda CRV
I have the same NOCO GB40. I wonder if those short clamps will even reach both post.
It's really not that far, pack goes on that indent on the fuse box area and both cables out the correct direction reach both points.
Your NOCO's protection of hooking it up wrong protected your truck.
Imagine what you could have blown using some cheaper charger - backfeeding into the DCDC Converter.
Ouch indeed.
SpaceyMac
Josh
Washington
'23 Ford Maverick Lariat 360 2.5L
Not trying to belittle concern, but this all sounds like user error.
1. Incorrect remote jump points used underhood.
2. NOCO and many other jump start have safety function that if voltage read is <2 volts, the jump start device will not recognize battery and not turn on. If cables are correctly attached can then press manual override button on NOCO (button with exclamation point). This allows you to force on the jump start function.
From NOCO GB40 manual:
Low Voltage Batteries & Manual Override. The GB40 is designed to jump start 12-volt lead-acid batteries down to 2-volts. If your battery is below 2-volts, the Boost LED will be "Off". This is an indication that the GB40 can not detect a battery. If you need to jump start a battery below 2-volts there is a Manual Override feature, which allows you to force "On" the jump start function.
! Manual Override Button To enable, push and hold for three (3) seconds. WARNING: Disables safety protection and manually forces Boost "On". Only for use when a battery is too low to be detected.
