How to jump start Maverick with dead 12V battery
Tony Davi
Tony
Hudson Valley NY
I am first time Hybrid owner and in reading I am confused if there is a way to "jump start" the vehicle, if the 12V battery goes dead. Planning to be traveling accross country with a light way camper in tow, and I want to make sure I don't get stuck along the way. I puchased this Power Bank. Will that do the job to start the vehicle?
Ford Maverick How to jump start Maverick with dead 12V battery Screenshot 2023-12-04 at 1.22.52 PM
Patrick
Gainesville, FL
2017 Ford Fusion Hybrid
I haven’t had to do it with my Maverick but my 2017 Ford Fusion Hybrid has been sitting mostly for the past 5 months, I forget to drive it every once in a while, and I’ve had to jump start it. My battery pack looks like it gives an error but as soon as I press the boost I can hear some tones like when you leave the lights on and I can remove the battery pack and start it like normal. It’s like it goes into hibernation and just giving it that little signal will wake it back up.
sprubs
New England
Nunya
I need to look into this. It's not jump starting like a normal car because there is no starter.
BeardedK
Kevin
22 Maverick XLT
Yes, it's exactly like jumping a normal car.
OP, there's spots under the hood, positive is covered by a red cap and the negative is a bare stud, that allow you to use cables or jump boxes. Take a look in the manual and you should be bale to see the process, but it's not difficult.
I had mine crap out on me and had to jump it a few times to get where I was going, power cable, super easy to do. And the jump pack you posted should work just fine.
Tony Davi
Tony
Hudson Valley NY
Thanks. I am making my way through the manual and will go find those connection points under the hood!
sprubs
New England
Nunya
The issue I've heard is that some of the boost packs are looking for a big load before they kick on. These hybrids aren't going to necessarily do that because there is no starter. I'm pulling this info from Toyota hybrids which I believe are very similar.
cyberdog
Ray
2023 Maverick Lariat Hybrid
Shouldn't be an issue. There's actually quite a bit of load when all the electronics fire up.
I've watched the voltage levels/SoC with the little BT monitoring device, and when first powered or for 40-50 minutes following key-on, there's quite a bit of load on that little battery. Enough that the SoC (State of Charge) will show ~35% vs 70%+, once that draw stops when the electronics finally shut down, with a corresponding change in voltage.
Probably why the most common time to see a 'Deep Sleep' message is within a couple of minutes of having taken a short drive, or having unlocked the door, even if just putting something inside the truck, and the voltage drops down below the threshold of ~12.1 volts.
BeardedK
Kevin
22 Maverick XLT
Maybe, but mine was as dead as a door nail and I was able to fire it right up all 3 times I needed to with my jump pack. And the dealer was able to get it on at least twice more.
sprubs
New England
Nunya
Just something to look out for when buying a boost pack. Some obviously work but I've read about certain models having issues working properly with hybrid vehicles.
Sarah Davis
Sarah
salina, Ks
2019 Fusion, 2017 Cmax
A simple jump pack will certainly work, we use one from Walmart that doubles as a phone charging bank so it has a dual purpose. but the one pictured should work great as well! jumping the battery is a little bit different, instead of red to red and black to black, you have red to red and black to a non painted bolt or a ground. there is a specific bolt that ford says to use, but I have talked to ford certified techs and they say any unpainted bolt will work.
bbhaag
On the hybrid there is a positive and negative post located under the hood. The positive is marked with a red cap and the negative is located up by the fender on the drivers side. A 2500A jump box is a little on the small side but it should do the trick if you have it fully charged.
This pics a little blurry but here are the locations of the under hood jump points on a Maverick hybrid.
Ford Maverick How to jump start Maverick with dead 12V battery hybrid maverick jump points
Tim d
Alpena
Ram
Ignorant here, no starter?
BoskoPColtrane
Bosko
I think the owners manual covers this.
Sarah Davis
Sarah
salina, Ks
Thank you! this picture should clear up all of the confusion on where everything is!
