Tune is meh 🫤
Saint D
24 terrain lariat
Ran my truck with a draggy type unit did 14.58 with down pipe, drop in filter, and 3” exhaust.
Flashed a 93 performance tune and ran a 14.55. I’ve honestly never had such a weak tune, is the 24 overwriting the tune? Basically in normal mode no tune the truck is a touch slower, but the tune fells almost identical to sport mode. I also feel like the truck launches harder without the tune (obviously a little 2 footing necessary)
Super underwhelmed for the money!!!
Jotis44
Ft. Myers, FL
23 Ford Maverick lariat
I just got a Livernois tuner a few weeks ago and couldn't be happier with it. Not sure what is going on with yours. Which one did you get?
Tim d
Alpena
Ram
Curious how much you paid for an unnoticeable change in performance ?
Saint D
24 terrain lariat
It’s same brand. Paid $575 from fast mavericks
I bought stainless works dp used for $600
Green drop in $50 from steeda
3” was an mbrp but I cut it up and added a muffler bought used for $300
Saint D
24 terrain lariat
Also 4k tow
Lighter 20lb 19x8.5 wheels
Tires are same weight at 26lbs
ndmiller
Noah
Atlanta
2024 Maverick XLT Azure Blue Metallic
Pick up the phone and call them. Something is wrong, as even the lightest tunes out there are 30-50 hp and turbos are seemingly very easy to gain power on. 2.0L turbos are abundant from a number of car makers (Ford, Hyundai, Honda, Porsche, etc) and most just above stock tunes are in the same range of power made.....About 10-20% more with 93.
Deleted member 30736
Guest
It sounds like a technical issue, perhaps the tune wasn't loaded.
EONR24
Swag
United States
2024 Ford Maverick XL
did you try simply removing and reloading the tune?
es7129
Ed
Long Island
Assuming DA & slope are the same there’s something off. The Livernois tune is good for a solid .5 second.
Snox801
Levi
Spring Lake Michigan
Yep sounds like it didn’t load the time.
I have several of the tunes from them and even my super safe 87-93 tow tune is noticeably more powerful than stock. I
Even if it added zero hp peak to peak the adjusting of the trq limiters per gear would make a significant difference.
Try reloading the tune. Make sure when you load it to check and make sure it’s loading the correct tune. With touch screen a lot of times I click on the tune I want but when asked it reads back a different one than what I thought my fat fingers clicked on.
Which tune file did you try and load? You just said tune. 91-93 octane? 87?
Snox801
Levi
If it helps I’ll video myself loading my tune and then link the rumble video here.
FischAutoTechGarten
Peter
Yeah, you kinda left out an important detail.....
The important detail is if he contacted FastMavericks / Livernois about the issue before sounding off on a social media platform.
Saint D
24 terrain lariat
I reached out directly 3 separate times, I’m in Michigan so local to me. Zero response. I’ve had very good response from tunes on vehicles in the past this my mod path follows my past vehicles. Just ordered cv intercooler this am
