towing package just for extra cooling?
dochawk
doc
Las Vegas
I'll start by admitting that I'm kind of paranoid about cooling, having lost more than one vehicle over the years to heat.
Actual towing with the maverick will be a non-issue: the things I would want to tow will be over 4k, and there's a bigger truck for me coming in the wake of the maverick anyway.
But the extra transmission cooling and bigger fan sure sound tempting.
The real tire isn't that important, as this won't generally be the distance driver (that will be classics and/or the full size truck).
Are there downsides to this package?
I assume the lariat still has a hitch without it--just for a bicycle, as after the "incident" a couple of years ago, I will no longer ride it to the wetlands! I'm done with riding on streets!
notfast
Los Angeles CA
Other than cost up front and maybe higher maintenance costs should the oil cooler need replacing, none that I can think of.
I always opt for a factory towing package if offered just for the extra cooling capacity.
NJBob
New Jersey
Only downside could be that the rear gear ratio is lower. May be slight hit to mpg. This is on the ecoboost. Don't know about the hybrid.
slashsnake
Minnesota
Tesla model 3, Kia Soul Xline
And the hitch comes stock on all trims but the XL (it's a $100 add on for that trim). so yes, on the Lariat, you'd get that either way. I don't currently need to pull over 1500, but a small travel trailer might be in my future. So between having it and not needing it vs. needing it and not having it, and the upgraded cooling, and the $100 already off for it (as I'd want the hitch either way) it was a simple choice for me.
Packer Bill
South Dakota
By ordering the 4k package, you will get a better resell value. Even if you don't tow, I recommend getting it. I see no negatives IMHO. Extra cooling is a good thing!
Frenchy
Bert
Taylorsville Utah
I ordered a 2025 Hybrid AWD with the 4K package even if I never ( now) plan on using it. I was after better cooling too but I learned that the hybrid does not get the larger radiator
The 2022 XLT without the luxury package did not come with hitch.
Frenchy
Bert
Taylorsville Utah
4K Tow Package
The 4K Tow Package (option code 53Q) is offered on the Maverick XL, XLT, and Lariat trims as a $745 option. It requires that Ford Co-Pilot 360 also be equipped, and is unavailable on front-wheel-drive (FWD) models. Content included in this package is as follows:
  • Trailer Brake Controller
  • Trailer Hitch (Class III) 2-inch Receiver w/ four-pin and seven-pin Connector
  • Transmission Oil Cooler
  • Higher Capacity Radiator (2.0L gasoline engine only)
  • Upgraded Cooling Fan
  • Conventional 17-inch Spare Tire (215/70R17)
Ford Co-Pilot 360 1.0
Speaking of Ford Co-Pilot 360 1.0 (option code 66C), this package is offered on XL and XLT trims as an optional extra that costs $795. Features bundled in this package are as follows:
  • Automatic Emergency Braking (AEB) Oncoming
  • Auto High Beams
  • Blind Spot Information System (BLIS) with Cross-Traffic Alert
  • Cross Traffic Brake Assist
  • Evasive Steering Assist
  • Lane-Keeping System
    • Lane-Keeping Alert
    • Lane-Keeping Aid
    • Driver Alert
  • Intersection Assist
  • Pre-Collision Assist with AEB
    • Pedestrian Detection
    • Forward Collision Warning
    • Dynamic Brake Support
  • Rear View Camera
  • Rear Parking Sensors
Jah.
Jah.
Central Florida
Fx4 package has larger radiator and larger fan for additional cooling . 4k towing option is definitely worth it imo . unfortunately was not available on mine as a dealer order and at msrp at the time . Took it anyway and happy with it .
Ford Maverick towing package just for extra cooling? 20240521_091725
dlhort1955
Milwaukee
Maverick FX4
I think my FX4 came with CoPilot 360. I am not sure because I never turned parts of it on or I turned it off or put it on minimum My wife hates it on her Edge, so why use it on my truck.
Blinky
Alberta, Canada
I got it on my 24. I don't tow often and I don't plan to start suddenly piling on the towing miles but I figured for the few hundred bucks it's better to have and not need than one day want it.
MoHillbilly
Missouri
2024 Maverick XLT
One thing I notice with the 4k towing package and the extra cooling capacity, now that the morning temps are dropping into the 30's, it's starting to struggle to hold it's heat up. Normal is 4 marks on the temp gauge, but on the cooler mornings (and they will get much colder as the winter comes in), it takes 4 miles or so at 55-60 to get up to temperature, then out on the interstate at 70 it drops back to three marks lite on the temp gauge. It comes back up when I pull off onto a side road, but I can already see when it gets down around zero there may be an issue. First year with the Maverick, so will see..
Frenchy
Bert
Taylorsville Utah
you could artificially block the cool air coming in. I used to work on old diesel equipment and they had these thermostatically controlled "fins" in front of the radiator. May be someone should do that again
