Total brake failure in 23 maverick with 8000 miles on it
Timothyd
I was going to the store in heavy traffic in Phoenix and hit the brakes nothing there….got to the dealer eventually was told the module imploded that controls the brakes…this could of been fatal for me I took a driveway instead of hitting the car in front of me then on his yard I hit the ebrake called ford got basically no where believe me this was a horrific situation…hope no one else has this experience
I very much miss the ol' hand brake in between the seats.
inline_five
2023 Hybrid XLT
Older Prius vehicles (not sure about new) use an electronic brake for the rear brakes and manual master cylinder for the fronts as a backup. It seems Ford only uses electronic braking for all four wheels which means no manual reversion should the electronic system fail.
The following is from Peake & Fowler Law Firm, Columbia, SC commenting on NHTSA reports.
So to feel 20 again I only need to make it to 65?
The Real Maverick
Jack
No. That's not true.
Every car on the road. EVERY ONE needs to (and is able to) apply the hydraulic brakes by physically pumping the brake pedal. I'm sure in some weird way that too could fail, but it wouldn't be computer or lack of electricity related.
Try this:
In a SAFE open area, like far end of a big parking lot away from others, get up to 20 mph. Put it in Neutral. Shut off engine, turn key off, push the off button in the others. You will be able to stop.
It will take effort, but the manual physical brakes will stop you. Or they should.
If not:
A) crap in pants
B) restart vehicle
C) apply the brakes again
I have never ever pushed the electric parking brake button with the vehicle in motion. I am skeptical it will do anything above 5 mph. But I don't know. I currently have a trailer attached so I won't be experimenting with that this weekend.
oysterville
Oregon
2024 Maverick Lariat
I really do hope that if there is a problem, the NHTSA is on top of it.
They've experienced impactful layoffs lately. I found a four percent figure, but unsure if that was the final total and what their roles were.
Tbone289
MO
You pull up on it actually. I've not tried pushing on it, but I don't think that works.
You really should experiment with it and be familiar with it in case you ever need it. It works at any speed. If you've ever experimented with using a hand brake in a car, you will likely be shocked at how effective the electric brake in the Maverick is. It gives very good power and control without locking up on pavement.
ctag
1998 Honda Civic, 2025 Ford Maverick XL 4K
Did the shop give you any more insight to what "imploded" means here? I'm assuming that was just a term of convenience to describe an electrical fault that kept the system from working, rather than something mechanical breaking (but not braking).
HenryFord
MO
Please do let us know what the dealer says failed. I preferred the older style e-brake that is a mechanical mechanism and was was easy to reach, and pull even when you might be panic'd. Sometimes simple just works. It may not be pretty, or fit in with the design esthetic but it has a purpose. Glad no one was hurt and I hope this incident was filed. We can't be fooling around with brake issues.
jsus
2022 Ford Escape Hybrid AWD
Why be skeptical of your owner's manual?
Applying the Electric Parking Brake in an Emergency
You can use the electric parking brake to slow or stop your vehicle in an emergency.
Pull the switch up and hold it.
The red warning lamp illuminates, a tone sounds and the stoplamps turn on when you use the electric parking brake in an emergency.
The electric parking brake continues to slow your vehicle down unless you release the switch.
Note: Do not apply the electric parking brake when your vehicle is moving, except in an emergency. If you repeatedly use the electric parking brake to slow or stop your vehicle, you could cause damage to the brake system.
https://www.fordservicecontent.com/...ingEnabled=False&userMarket=USA&buildtype=web
Tim d
Alpena
Ram
Glad your ok! And if problems id be contacting ford.
ripperAZ
AZ
2022 Mustang MachE 2021 Genesis G90 2032 Mav
Law enforcement! Ha! I watch tv and the “Law Enforcement” on tv has more validity than the “T” streets of his so called ‘reality’! Ooh, that damn ‘T’ word!!! And no, not Texas! 😉 Pope Donny, that’s not bad is it!
Ford Maverick Total brake failure in 23 maverick with 8000 miles on it IMG_7860
daver401
Lincoln Nebraska
2023 Maverick XLT
The manual states the parking brake lever can also be used periodically for a short time. That is assuming the manual lever does not go thru the same modules. In a panic it is also hard to remember this unless the parking brake is used on a regular basis.
The Real Maverick
Jack
It's an electrical button.
And I push it towards the rear.
Try it. It works.
Pulling buttons is crazy.
Chilipepper
Pete
Louisiana
Lincoln was
If the police were called out to the incident and they had to handle the report for an accident they just have to make sure that the roadway is clear of the vehicles involved.
If one of the drivers requested a tow of their vehicle and doesn’t have a tow company to call then the police dispatcher will call the next tow service on the call list to come out.
The police don’t tell the driver not to drive the vehicle it’s the owners decision whether to have it towed or drive it home or wherever.
If you are crazy enough to drive the vehicle with failed or faulty brakes then it your choice.
