Tires warping at 6,000 miles
JimParker256
Cedar Park, TX
Normal for cheaper tires. I have worked setting the machines that build those tires. Continental is a crappy tire. Michelin construction is better.
I think with tire production, like pretty much all other build processes, it comes down to the fact that you have three controllable factors:
  1. Quality
  2. Speed of manufacture
  3. Cost to build
You ge only pick two of those, or your goods are so expensive that you're priced out of the market.
Continental makes some excellent tires at the upper end of their product lines. Michelin seems to make good products in the middle of their line, but not so great at the upper end. Your mileage (and tire quality) may vary...
Joseph Cobbs
Joseph
Puerto Rico
Maverick XLT, Mustang, Honda Type R, Honda Fit
My Maverick has the same "Crease or small linear dent in tire sidewall. My dealership said that it was just a small defect in the tire. No need to replace it.
T-Dog
Ted
2023 Maverick Lariat FX4
I stopped by my local Ford Dealer. I noticed some significant warping on all four tires. The manager alleged, that due my driving it was my fault.
the evidence is sustained from the manager interpretation of the cause. There were no calibrated tools or measurements taken. Just some photos with an iPhone. It’s been three business days, and no response yet.
anyone else seen this before?
I'm a former tire engineer. As stated in other posts, you have nothing to be concerned about. The area you refer to as warped in your pictures is actually where there is an overlap
I am a former tire engineer. The condition is actually where the radial ply overlaps. Contrary to what appears as a defect, is actually the strongest portion of the sidewall. Your dealer needs to educate themselves about tires. Shocked that they blamed you. SMH.
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
Mine are like yours not as bad, some one on the website said it was from the straps on the cargo train , do not think so ,it is because they are single ply sidewall tires . I have always disliked them and will be changing them out when I get new rims fro. Discount Tire in November. Diffently not the way we drive..
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Sorry I'm late to the conversation. I know your question has been answered, but radial indentations are prevalent in the vast majority of radial tires. Some are just more noticeable than others. Completely normal condition. That being said, if the indentation is severe, it can be adjusted by the manufacturer on a prorated basis, but not many folks are gonna go through that hassle.
Ford Fanatic
Billy
2055 Mike's Road Conway, S.C.
2022 Ford Maverick XLT.....2022 F-150...2022 Ford
My Dealer...Conway Ford in Conway, S.C. replaced all 4 Continentals on my Maverick with 4 new Goodyears at 700 miles...the tire sidewalls had indentions in them...I didn't like it, he replaced them.
lagrene
Milton
New Orleans
Ford Maverick XLT
In my experience problems with tires are dealt with at the appropriate tire dealer. A Continental tire dealer in this case.
RedRider
Kitchener, Ontario, Canada
Sorry, I have to disagree. I worked in a tire plant too, in QC. Assuming that these indentations are not due to broken tread plies, it is where the tire was mis-built to incorrectly overlap the plies, that means that while yes, they are technically stronger in this small area, but they also run hotter and cause the tread in that part of the tire to squirm when it shouldn't, leading to premature failure. If you designed or built tires like that, I'm glad I do not use them.
Srm1
SF Bay Area
Ford
Spend 30 years working on tires in the field. Never had an issue with overlap. T-Dog 100% correct.
Mightybeast
Adam
Oklahoma
Maverick hybrid
Funny thing I have the same thing on my tires. Originally I thought they were overinflated, since Ford up was showing 42 psi on delivery. But after dilation they remained the same.
Maverick Grabber
Indiana
2015 Chrysler 200, 2022 Maverick XLT Red
I had a nail in the sidewall at 1000 miles had to get the same to match treads and the dealer told me to expect to replace them all about 35,000. When the time comes I'm going with Bridgestone Ecopias
IGNIGNXKT
Daz
Arizona
Honda Insight
Happens here in phoenix with the heat. Usually happens on cheaper grade tires. Regardless, as others said, not dangerous. You get what you pay for. These aren’t made for looks or performance. Likely as thin and cheap as possible to simply get you to be on your way. Like most if not all stock tires on a new car, they’re not exactly designed to last as long or to be as nice in general as tires off the rack.
dhill59
2023 Maverick XLT
This is “normal” for radial tires. The old bias ply tires did not do this. Just go to a parking lot, look at the tires on all the vehicles. Every make of radial tires will have it, some more pronounced than others…
I beg to differ. My wife's Honda has Michelin's - zero dents and my Miata has Bridgestone's - zero dents. The Maverick with Continental's is batting 1000. All four have multiple dents each.
Lou'sBluMav
Lou
Upstate SC
2004 Chevy Colorado(sold Oct) 2018 Subaru Forester
@T-Dog is correct. Tires are built up in layers on a cylindrical form. The indentation is caused by a too heavy splice of the carcass layer, thus it is stronger, and on inflation is more constrained. There should be no more than one sidewall indentation (at the same place on both sides) per carcass ply.
However, IT IS a cosmetic defect, and at this degree should be sold as a blem. The tolerance for the amount of deflection before being blemed or scrapped varies among manufacturers. You can go thru a parking lot and get an idea of which brands have better manufacturing control.
You should go to the tire dealer for this kind of problem, use the car dealer as a last resort ( they barely know anything about cars, and almost nothing about tires).
