- First Name
- Steve
- Jul 21, 2021
- coppell tx
- 2023 Ford Maverick Hybrid
- Engine
- 2.5L Hybrid
What Happens When You Drive On Overinflated Tires?
There are several areas of concern when it comes to driving your vehicle with tires that are overfilled with air.
Loss Of Traction And Reduced Braking
One of the biggest problems is going to be a loss of traction, particularly on wet pavement. Over inflation reduces the contact patch between the tire and the road. The result is worse traction, less grip and reduced braking performance. Wet roads only magnify the situation. Altogether, this can quickly become a recipe for disaster during an emergency maneuver.
Uneven Treadwear
The same traction and handling issues due to a much smaller contact patch will also create uneven treadwear. Since only the middle portion of the tire is making contact with the road surface, it only stands to reason that the middle of your tire is going to wear much quicker.
Decreased Ride Comfort
Driving on overinflated tires is somewhat similar to riding in a covered wagon. The ride is rough, jarring and unforgiving. The tire lacks the ability to absorb any of the impact from road imperfections because it is overinflated. Not good, unless visiting your chiropractor for a back adjustment is something you look forward to.
https://tirereviewsandmore.com/driving-on-overinflated-tires-is-it-dangerous
Uneven Treadwear
