This is the best air compressor I've ever owned
mamboman777
Josh
NRH, TX
I got it from https://tozalazz.com/ but you can order it directly from amazon.
Ford Maverick This is the best air compressor I've ever owned 20230312090234_IMG_4594
Comes in a nice carry case that fits everything.
Ford Maverick This is the best air compressor I've ever owned 20230312090423_IMG_4599
Here's the compressor itself. Everything about it screams "quality!". Heavy duty carry handle, wide metal plate on the bottom (helps prevent tipovers), rubber feet underneath, and dual piston design! I hadn't heard of dual piston till I started looking at new compressors recently, but I'm a believer; it doesn't get hot and is FAST; to the tune of 11.65CFM. That means you can airup 330L/min at 0 PSI.
Ford Maverick This is the best air compressor I've ever owned 20230312090343_IMG_4596
Ford Maverick This is the best air compressor I've ever owned 20230312090330_IMG_4595
Long hose with quick connector on one end and standard Schrader valve on the other.
Ford Maverick This is the best air compressor I've ever owned 20230312090357_IMG_4597
Comes with Schrader to Schrader quick connect adapter.
Ford Maverick This is the best air compressor I've ever owned 20230312090406_IMG_4598
Comes with some standard attachments.
Ford Maverick This is the best air compressor I've ever owned 20230312090441_IMG_4600
This compressor is so powerful, you have to connect it directly to your battery. *insert Tim the Tool Man grunts*
Ford Maverick This is the best air compressor I've ever owned 20230312091337_IMG_4604~2
Connection to 12v is easy for the hybrid. The best part is the long air hose can reach any tire on the truck. No more cigarette lighter fire drill exercise to get to different tires.
Ford Maverick This is the best air compressor I've ever owned 20230312091327_IMG_4603.JPG
I was shocked, but it's actually quieter than my old compressor. 😲
Ford Maverick This is the best air compressor I've ever owned 20230312091223_IMG_4602.JPG
Ford Maverick This is the best air compressor I've ever owned 20230312090140_IMG_4593
The best part, it fits perfectly under my back seat.
If you're in the market for a compressor, you can't go wrong with this one. This is the best one I've ever owned. Highly recommended.
mamboman777
mamboman777
Josh
NRH, TX
dcs12345
TX
07 Chevy
Clarkdonbran
mamboman777
mamboman777
Josh
NRH, TX
fossil
ernie
ohio
mamboman777
mamboman777
Josh
NRH, TX
wind powered?
OK...you got me...I use battery power all the time. What I'm not a fan of is battery powered tools. I got sick of the tool being out of juice when I needed it. And buying replacement packs every year. And limitations on power...no thank you. I'll use the plug in version.
CTYankee
Central MA
2022 Maverick XLT
... I'm not a fan of is battery powered tools. I got sick of the tool being out of juice when I needed it. And buying replacement packs every year. And limitations on power...no thank you. I'll use the plug in version.
No worries. I'm not a fan of having to clamp wires onto the battery to inflate a tire. I haven't had any issues with batteries being out of juice. I keep an extra battery or two on charge and swap them periodically to prevent that. But what works for me doesn't necessarily work for others, so both types have their place.
TCPTX65
2023 Maverick XL Hybrid, 2023 Buick Enclave
mamboman777
mamboman777
Josh
NRH, TX
fossil
ernie
ohio
I've got one of those battery types, 20 volt and it works well for Maverick sized tires and pressures. Clamp it on the stem, set the auto off pressure and let it work.
I even bought a 12vdc 1hr charger to charge the 4.0AH amp batteries when in my truck, think it was about $40. Nice and handy for lite yard work at the family camp, trimmer, sprayer, saw.
Waterick
Laurens county SC
Let us know how it holds up in regular use over a couple of years. I have yet to see a 12 volt compressor durable enough for more than occasional use.
mamboman777
mamboman777
Josh
NRH, TX
While I don't anticipate any problems, it does have a two year warranty.
